Re: Who has installed Moog offset upper cont. arm bushings? [Re: jsully] #137075
10/17/08 11:01 PM
10/17/08 11:01 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Well I installed the offset bushings in the arms today, but I only replaced the front bushings with a offset ones and left the rear ones along. The reason was that I received a PM from another member hear telling me that if you install the rear ones with the arrow pointing inward the outer edge of the control arm will hit the inner fender. I took one of the offset bushing and slipped over the eccentric adjuster bolt installed in it's rear position and when I turned the arrow inward the outer edge of the bushing was almost hitting the inner fender. So it sure looks like if you press the rear offset bushing in with the arrow pointing inward you will have an interference problem. If that is true, then I don't see any valve in using them the the rear position.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137076
10/18/08 07:13 AM
10/18/08 07:13 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Spicer and NAPA also have the offset bushings. Both made in USA.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137077
10/18/08 11:43 AM
10/18/08 11:43 AM
Arizona
jsully Offline
jsully  Offline
Arizona
Please let me know if you get the alignment numbers you were after. This was concern was mentioned on an earlier thread.
If you do, this is good info!
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137078
10/18/08 03:01 PM
10/18/08 03:01 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
An update and a correction to my above statement.
Today I installed the upper control arms today and found out that with the rear arm adjusters cranked all the way inward, there was still about a 1/4" clearance between the edge of the arm and the inner fender. So I now say go ahead and install the offset bushings in the rear position also and press them in with the arrows pointing inward. Clearance should Not be a problem. So now it looks like it back to the machine shop to press in the offsets in the rear.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137079
10/22/08 07:36 PM
10/22/08 07:36 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Last update:
I pressed in the other two offset bushings in the rear and reinstalled the upper control arms. For a test, I adjusted the cams so the the rear of the arms were all the way in and the front of the arms were all the way out. There was no interference between the rear of the arm and the inner fender when I moved the arm through it's travel. Since the car is put away for the winter, I won't be able to get the front end alignment done until spring of next year. It looks like I should be able to get plenty of positive caster now.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137080
10/22/08 11:49 PM
10/22/08 11:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Last update:
Re: Who has installed Moog offset upper cont. arm bushings? [Re: autoxcuda] #137081
10/23/08 12:14 AM
10/23/08 12:14 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
autoxcuda, how much positive caster are you running and what was the driving results? Is the steering effort much harder that before?
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137082
10/23/08 12:44 AM
10/23/08 12:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I have power steering. It's a mopar part remanufactured box I bought in 1993.
Not hard to turn at all. I even have a smaller 15" LaCarra steering wheel (stock IIRC is 17"). Steering wheel diameter is part of the leverage in the system.
I rebuilt the suspension not much after I got the car in '93 with most all the handling goodies I have now including the offset bushings. I've always had over 3 degrees of positive caster.
Current alignment is....
4.4 postive caster
1.5 negative camber
1/16" toe in
I really upped the camber this time. I've done, .5, .75, and 1 deg neg since 1993. I've always worn the outsides edges . So I gave 1.5 neg camber a try. I think the increase this time, really made for a crisp "turn in" at speed. Like very quickly changing lanes on the freeway at 70 mph getting the tire to squeak a little
All that with stock upper control arms BTW.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: autoxcuda] #137083
10/23/08 01:23 AM
10/23/08 01:23 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
autoxcuda, thanks for the input. I'm shooting for:
+2.5 degs. caster
-1/2 deg. camber
1/16" to 1/8" toe in.
I got these specs. from Rick Ehrenberg.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137084
10/23/08 01:28 AM
10/23/08 01:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
+2.5 degs. caster
-1/2 deg. camber
Do you have manual or power steering?
What size front tires do you have on it?
I'd go another degree of positve caster to 3.5 degrees postive. Gives you some camber gain when cornering too. Is it your daily driver? What's your realistic milage per year?
Re: Who has installed Moog offset upper cont. arm bushings? [Re: autoxcuda] #137085
10/23/08 01:57 AM
10/23/08 01:57 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
It's a 68 Charger with power steering. The tires are 225-70-15" red wall radials on all 4 corners. I'm was just looking to improve the straight line stability. Right now I think the car has like 1/2 deg positive caster and it wanders some when you are driving in a straight line on the highway also the steering wheel is slow to return to center coming out of a turn.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: rarefish] #137086
10/23/08 02:20 AM
10/23/08 02:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Caster it up! The camber will help too. Being in New York and looking at the car, I'm wild guessing you put under 5K miles on it a year (I could be wrong though). But with under 5K miles a year, I'd go a little more aggressive with the alignment.
In the scheme of things, you're going to wear the tires out in 8 year instead of 10 years. Why not enjoy those 8 years of driving a little more?
BTW 5K/year is averaging 96 miles each one of the 52 weeks a year.
Re: Who has installed Moog offset upper cont. arm bushings? [Re: autoxcuda] #137087
10/23/08 03:27 AM
10/23/08 03:27 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
The car only has 36k mikes on the clock. It is all factory original except for the wheels and tires. I have owned it 2-1/2 years. Since then I have only put 1k miles on it. There are some people who think I should not drive it at all, but I don't own a trailer so It will get driven to Carlisle and other shows each year.
