which pistons for my 440 for 9.3-9.5:1 with 80cc heads? #1370608
01/16/13 02:16 AM
01/16/13 02:16 AM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
I'm putting together a 76 440 with a steel crank (stock stroke) +.030 with a set of 440 source stealth heads. They advertise 80cc chambers. Can someone help me figure out a set of pistons/rings to use for a comp ratio between 9.2-9.5:1? The combo will be used with an xe274 cam, roller rockers,performer rpm intake,4160 750cfm carb, and headers.thanks!
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 78asprin] #1370609
01/16/13 03:42 AM
01/16/13 03:42 AM
With aluminum heads I would pump the compression up to 10.00 to 10.5. Try looking at KB Icon pistons or United Machine for the KB hypertutitec(SP?) pistons for that application
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 78asprin] #1370610
01/16/13 12:06 PM
01/16/13 12:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A flat top at zero deck with 5cc valve reliefs , .041 thick gasket and 80cc heads comes in at 10.46.
A 15cc dish/valve reliefs will bring it down to 9.5.
What is your reason for wanting 9.0 -9.5 ?
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: JohnRR] #1370611
01/16/13 09:08 PM
01/16/13 09:08 PM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
well its for a daily driven truck, running pump gas, didnt think i could go much more than that with pump fuel. id like to squeeze as much as i can without having to run any special fuel or anything.can i go higher than that because of the aluminum heads?
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 78asprin] #1370612
01/16/13 10:53 PM
01/16/13 10:53 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I'm running 9.5:1 compression with open-chambered iron heads with no quench and it is running fine on 91 octane pump gas with no pinging. I run it hard and race it on the 1/8 mile whenever I get a chance with no problems.
I plan on swapping on some Stealth heads when I get some more money and time and I think it will run fine with the smaller 80cc chambers and higher compression.
If you get some TRW 2355 pistons that will get you close to zero deck and give you a workable compression ratio with the Stealth heads. Lots of people are going to say these pistons are too heavy, maybe there's something else someone can recommend that is as reasonably priced that will get you close to zero deck and a good ballpark compression.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 67Satty] #1370613
01/17/13 08:46 AM
01/17/13 08:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm running 9.5:1 compression with open-chambered iron heads with no quench and it is running fine on 91 octane pump gas with no pinging. I run it hard and race it on the 1/8 mile whenever I get a chance with no problems....
Have you tried 87 octane just to see how the engine responds?
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 67Satty] #1370614
01/17/13 08:56 AM
01/17/13 08:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you had quench, and depending on the cam , you could have gotten away running a lower octane fuel.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 6PakBee] #1370615
01/17/13 08:58 AM
01/17/13 08:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It would be an interesting test , but I think he would have an issue without quench, unless he is at a higher altitude.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: JohnRR] #1370616
01/17/13 12:40 PM
01/17/13 12:40 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Where I drive around town is pretty close to sea level, or actual sea level when I drive to the beach. Where I race 1/8 mile is at 1700 feet.
I'll have a quench motor when I step up to some aluminum heads. Also going to change to a solid lifter cam but that's a different topic.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: JohnRR] #1370617
01/17/13 01:12 PM
01/17/13 01:12 PM
or run a faster (ign) curve for more power if you wanted to stay with 91
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: RapidRobert] #1370618
01/17/13 01:38 PM
01/17/13 01:38 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Yeah, that's what I'm doing.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 67Satty] #1370619
01/17/13 09:49 PM
01/17/13 09:49 PM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
so would i be ok with say 10-10.5:1 compression on pump fuel then? 440 source says these heads have a quench area in them. im looking at the ross 82008 pistons, they seem to be fairly light weight and the price is right. what do u guys think?
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 78asprin] #1370620
01/17/13 09:56 PM
01/17/13 09:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
10:1 yes.
10.5:1 maybe not.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: 78asprin] #1370621
01/18/13 01:27 AM
01/18/13 01:27 AM
Yes you can with aluminum(they suck more heat out of the combustion chambers than iron heads do ), usually by 1 full point My pump gas stroker has 10.78 to 1, I run Oregon 91 octane, non ethanol, pump gas, 9.97 ET at 134.6 MPH at 3450 lbs through the muffs with the air cleaner on motor only I have a wideban on my car, I run it a little lean on the air fuel ratio, 13.3 to 13.5 at WOT and I have no signs of detoonation on the spark plugs or in the motor I've raced it at sea level, even with the D.A. 800 ft. below sea level and it runs fine on the local pump swill with that compression ratio IHTHs
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: Cab_Burge] #1370622
01/18/13 01:45 AM
01/18/13 01:45 AM
anacortes,wa
78asprin Offline OP
78asprin  Offline OP
anacortes,wa
Sweet deal! Damn that sounds like u have quite the setup!
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: Cab_Burge] #1370623
01/18/13 08:19 AM
01/18/13 08:19 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cab, be careful on what you put out there as it sounds like the OP is kanda new to some of the technical aspects. I don't know if you meant it or not, but is sounds like your telling him he can run 10.8:1 CR because you can. Just not worth directing a guy to be potentially a couple of tenths to high vereses leaving a couple on the table.
Re: which pistons for my 440 for 9.3-9.5:1 with 80cc heads? [Re: BSB67] #1370624
01/18/13 11:04 AM
01/18/13 11:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
OP shoot for 10 for your application and you will be safe and not disappointed.
