Firewall insulation install question #1370606
01/16/13 02:00 AM
01/16/13 02:00 AM
southern Idaho
moparcyco Offline OP
southern Idaho
Hey guys just wondring if this gets any kind of adhesive?I got the oe plastic nails,but was just wondrring if the factory used adhesive also.Thanks
Re: Firewall insulation install question [Re: moparcyco] #1370607
01/16/13 09:34 AM
01/16/13 09:34 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
No adhesive on the yellow insulation pieces, only shoddy pad is installed with adhesive
