What manual trans 7000rpm 800lbft street driven
#1370466
01/15/13 10:06 PM
01/15/13 10:06 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Probably been beat to death but oh well. I need consistent shifting at about 7000 RPM. Has to hold up to 800lbft. Can be granny shifted as well. I thought the TR6060 was the answer, people complain of grinding 1-2 shifts at about 6000 rpm. A Jerico or comparable race trans has to be shifted quick and firm every time...(correct me if I am wrong please) My 833 complains at 6200rpm. Is this asking too much of a cone synchro type trans.. I realize the shifter, linkage, clutch all play a role. As well as traction determining durability. The "tranzilla"? Or no matter what is it just a high maintenance component?? Thanks Curt
Oh yeah...THAT'S gonna leave a mark!
Re: What manual trans 7000rpm 800lbft street driven
[Re: Curt]
#1370467
01/15/13 10:18 PM
01/15/13 10:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If your A833 is complaining at 6200 rpm you probably need thinner oil in it.
As for the rest, dunno, you delving into an area that is off the beaten path. You're essentially asking for a hard core race trans with mild mannered street characteristics.
[Re: Curt]
#1370468
01/15/13 10:21 PM
01/15/13 10:21 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I can shift my face-plate Richmond 5-speed at 6800 RPM My clutch is set-up to be easy on the drivetrain though so maybe you should ask "what clutch wont destroy my drivetrain choice" Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1370469
01/15/13 10:35 PM
01/15/13 10:35 PM
Curt
JAX FLA
Doesnt the faceplating get nicks and burrs if not shifted "rudely"? Curty
[Re: fourgearsavoy]
#1370471
01/16/13 03:34 AM
01/16/13 03:34 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Gus may I ask how heavy you car is what kind of tq numbers do you estimate at the fly wheel? As you know I am in the same boat. There is a NOS Nash 5-speed that is supposedly a special drag racing model for around 2k that has peaked my interest.
[Re: Jeremiah]
#1370472
01/16/13 09:14 AM
01/16/13 09:14 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
how many gears do you want? On the viper forums they say that the stock viper T56 can hold 800 hp, but starts to show it's weakness above 900 hp. but...in an older car it won't exactly bolt in, so that's something to consider as well.
no idea how many RPM they shift those gearboxes at though.
**Photobucket sucks**
[Re: 68LAR]
#1370476
01/16/13 01:28 PM
01/16/13 01:28 PM
dogdays
[Re: dogdays]
#1370477
01/16/13 11:46 PM
01/16/13 11:46 PM
Curt
JAX FLA
I have heard shifting problems with the t56's at higher rpm. Could care less about cutting up the floors. Did not think the lenco trans was suitable as a street trans under constant accel and decel use? Maybe should think about gear coupling systems? Cone synchro, face plated, dog rings? Someone point me in the right direction... Thanks Curt
[Re: Jeremiah]
#1370479
01/17/13 12:07 AM
01/17/13 12:07 AM
Curt
JAX FLA
73 challenger no weight reduction,10 point cage... Please tell me why this matters for shift rpm and torque capacity...hopefully i can learn something here. Curt
[Re: fourgearsavoy]
#1370482
01/17/13 12:34 AM
01/17/13 12:34 AM
Jeremiah
Rogue River, OR
I am not quite sure of my torque figure but the Wallace calculator puts my engine in the 635 HP range with my ET and weight of 3660 with me at the wheel. I will be trying a new Centerforce dual friction set-up this year to see how it works with my combo I am putting the 18 spline HEMI box with syncros back in for street use and putting the Richmond 5-speed on the shelf for a while along with my Hays Mark XII plate and Ram six puck disc. That Nash box sound interesting and it should hold up pretty well with your application Gus
Thank you for the info. It sounds like you are taking a break from racing the car. One of the reasons I don't like the idea of going to a lenco is losing my h-pattern shifter. I'm old school like that I guess. For now my fortified 18 spline box will be fine so I have some time to learn/research/shop. I'll let you know what I find out on the nash box.
[Re: Jeremiah]
#1370483
01/17/13 01:20 AM
01/17/13 01:20 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
My train of though was leaning towards the idea that a heavier car with more torque is going to be harder on the syncro (or whatever you decide to use) and a heavy car is going to create much stress on the transmission. It seems to only be an issue if you are racing the car on a surface that provides good traction so you may be ok for a street car. In my case me 3600 lb. car is going to need a very strong transmission to be reliable for both the abuse of drag racing and still retain the ability to be street driven (down shifted, etc). Personally I like to overbuild stuff because I tend to only spend the money once instead of multiple times.
Something that comes up from time to time with us older racers is, what is harder on a drive line, "granny shifting" or "power shifting"? Most of us old guys, not all, but most, feel that granny shifting is harder because of the "loading and unloading" of the drive line. Obviously a heavier car will be harder on drivetrain parts. That's why I try to "cushion" the hit by slipping the tires a bit. Slipper clutches accomplish the same thing, but fot me, they are too high maintenance and expensive. Buy that's just me.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: fourgearsavoy]
#1370484
01/17/13 09:30 PM
01/17/13 09:30 PM
Curt
JAX FLA
Why are you putting the 833 back in? What exactly make the nash box unacceptable on the street? Thanks Curt
