5.2 intake leak trouble shoot. ??? #137043
10/15/08 08:55 PM
10/15/08 08:55 PM
Pittsburgh, PA
1970440RT Offline OP
Pittsburgh, PA
I have a 318/5 speed 97 Ram with 150k on it. I replaced the intake manifold and plenum gasket at about 110,000 because I was using and saw oil down through the throttle body. Everything is OK until now. I'm using oil again like crazy and it is pinging under load. This time I do not see oil down through the throttle body. I am also getting a surge at idle EXCEPT when the AC compressor is engaged. For some reason the idle smooths out when I hear the clutch engage.
I decided to follow the steps in the TSB to detect a leaky manifold gasket:
1. disconnect breather hose from manifold and attach Vaccuum guage to hose. -done
2. disconnect pcv hose from manifold and pcv. Cap pcv and manifold. -done
3. start engine. do not let crankcase build pressure to more than 3 psi. -done
I have 15" of vaccuum! When I give it some gas it drops to 7-8".
Is this supposed to be 0" of vaccuum? I just want to make sure that the gasket is bad again before I throw money at it.
Re: 5.2 intake leak trouble shoot. ??? [Re: 1970440RT] #137044
10/15/08 09:31 PM
10/15/08 09:31 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
I just had to change mine again this summer, only this time I installed the Hughes aluminum plate. If you plug the PCV side on the manifold and start the engine, the breather side hose from the valve cover should not have a vacuum on it. While running, you should hold you finger over the hose and it should build up a little pressure, if it is pulling, then your gasket is shot.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: 5.2 intake leak trouble shoot. ??? [Re: wildman340] #137045
10/16/08 07:17 AM
10/16/08 07:17 AM
Pittsburgh, PA
Pittsburgh, PA
Unreal, I can't believe a small leak in the plenum will allow the crankcase to pull 15".
Just making sure I was toubleshooting correctly. Thanks.
Re: 5.2 intake leak trouble shoot. ??? [Re: 1970440RT] #137046
10/16/08 07:23 AM
10/16/08 07:23 AM
ky.
K
kenworth_goose Offline
K
ky.
It's the lower intake gasket on the bottom of the intake. Remove the intake, flip it over, remove the plate on the bottom, reinstall the intake. I have no idea why they ever even put this on there.
