Testing a Alt gauge #1370161
01/15/13 01:00 PM
01/15/13 01:00 PM
Arkansas
beatupcuda Offline OP
Arkansas
How do you test a alternator gauge when it's out of the dash ?
67-68-69 cuda ?
thanks
68 Hemi 4 speed Cuda,,,,building ?
Re: Testing a Alt gauge [Re: beatupcuda] #1370162
01/15/13 01:14 PM
01/15/13 01:14 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
with a multy meter but you need current to be flowing threw it so it has to have a power source and a draw??
http://www.ehow.com/how_7943382_test-amp-gauge.html
Re: Testing a Alt gauge [Re: beatupcuda] #1370163
01/15/13 02:55 PM
01/15/13 02:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Think you could use a sealed beam (high beam) and a battery positive to the amp gauge to the sealed beam and grounded back to the - on the battery!
maybe a little switch to turn it off and on but not needed then test multy meter against gauge? should work.
Re: Testing a Alt gauge [Re: Dodgem] #1370164
01/16/13 01:05 PM
01/16/13 01:05 PM
Arkansas
Arkansas
thanks !!!
