Page 1 of 4 1 2 3 4
My New Bullet; a 454 Small block #1369539
01/14/13 07:43 PM
01/14/13 07:43 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
As most of you know, my last engine met an untimely demise. If you wish to review, that thread can be seen HERE
Many have asked over the past few months what the old motor was/is being replaced with, and assuming you read the title of this post before clicking, you now have your answer. I bought this engine complete, and have taken it down to the block and am replacing and upgrading where I feel is warranted and my budget will allow.
Here are the specifics:
Siamese, 59 degree R3, bushed lifter bores
BPE 4.25" crank
4.125 bore
Venolia Flat Top piston
12.75:1
6.125" Eagle H beam
Brodix B1-MC's by Koffel
Crane cam .619/.641 278/284@.050 108 LSA
Comp 8043 lifters
T&D 1.5 ratio paired rockers
Pushrod oiling
Ritter 420 intake, ported and opened up to Dominator flange
BG 1050 Dominator, will probably get converted for E85 use.
Hooker 2" headers 3.5" collector meant for W2/W5 application with adapter plates.
Crank trigger
CSR water pump
Intake Flow@28"
0.100 83
0.200 150
0.300 205
0.400 255
0.450 275
0.500 281
0.550 290
0.600 300
0.650 310
0.700 315
The block and rotating assembly are at the machine shop, they should be making their way back to me this week! Then the reassembly begins.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369540
01/14/13 07:46 PM
01/14/13 07:46 PM
Renton Washington
Renton Washington
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369541
01/14/13 07:47 PM
01/14/13 07:47 PM
Renton Washington
Renton Washington
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369542
01/14/13 07:50 PM
01/14/13 07:50 PM
Renton Washington
Renton Washington
Unknown lifters we believe to be Cranes, compared to the 8043 Comps. Thank you Brian at IMM for pushing to have these made.
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369543
01/14/13 08:12 PM
01/14/13 08:12 PM
oregon
greendart408 Offline
oregon
Re: My New Bullet; a 454 Small block [Re: greendart408] #1369544
01/14/13 09:25 PM
01/14/13 09:25 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
That is gonna be a bad hot rod man! Good to see you'll be back up and running shortly. Congrats!
Wes
Re: My New Bullet; a 454 Small block [Re: EvilB1Dart] #1369545
01/14/13 10:23 PM
01/14/13 10:23 PM
Guitar Jones Offline
That's nice and although I'm not one to judge I never liked those Brodix heads. I haven't seen any car with those heads that really runs strong, I sincerly hope yours is the exception though. Good luck.
Re: My New Bullet; a 454 Small block [Re: Guitar Jones] #1369546
01/14/13 10:29 PM
01/14/13 10:29 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yikes thats what I was thinking. those cubes would like more head I think but it still should run good
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369547
01/14/13 10:29 PM
01/14/13 10:29 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Very Nice! Outta run hard
Re: My New Bullet; a 454 Small block [Re: Forest] #1369548
01/14/13 10:37 PM
01/14/13 10:37 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Damn Dustin, you went BIG! Nice!
What in the motor are you changing? Or is the stuff you listed going to be the final setup for it?
If I remember correctly you had an 8 point bar in the car right? Might need a 10 point cage now lol
Re: My New Bullet; a 454 Small block [Re: Forest] #1369549
01/14/13 10:38 PM
01/14/13 10:38 PM
Arizona
Chris'sBarracuda Offline
Arizona
Looking Good Dustin...
Chris..
Re: My New Bullet; a 454 Small block [Re: Chris'sBarracuda] #1369550
01/14/13 10:43 PM
01/14/13 10:43 PM
Between a rock & a hard place
cudadoug Online content
cudadoug  Online Content
Glad to see you on the mend...
That moder will test them there Cal Tracs!!
Re: My New Bullet; a 454 Small block [Re: cudadoug] #1369551
01/14/13 10:47 PM
01/14/13 10:47 PM
ohio
all spooled up Offline
ohio
nice that should do the job ps did it come from houston texas
Re: My New Bullet; a 454 Small block [Re: all spooled up] #1369552
01/14/13 10:53 PM
01/14/13 10:53 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
You got some good looking stuff there. I bet your going to be pleased with the finished product.
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369553
01/14/13 10:54 PM
01/14/13 10:54 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Could we have a picture of the lifter gallery?
Re: My New Bullet; a 454 Small block [Re: all spooled up] #1369554
01/14/13 11:08 PM
01/14/13 11:08 PM
Fireguy or something like that? His car should have run well into the 9's but only ran like 10 0's?
Re: My New Bullet; a 454 Small block [Re: MattW] #1369555
01/14/13 11:10 PM
01/14/13 11:10 PM
Renton Washington
Renton Washington
Everything I listed is how it is going back together. Parts were changed for various reasons.
This image is with the old lifters as I took it apart.
-Dustin
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369556
01/14/13 11:14 PM
01/14/13 11:14 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thx you just answered a bunch of questions I had. Matt
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369557
01/14/13 11:15 PM
01/14/13 11:15 PM
I would love to have that short block. Good luck to you.
Re: My New Bullet; a 454 Small block [Re: Triple Threat] #1369558
01/14/13 11:20 PM
01/14/13 11:20 PM
You might want to buy a couple of the Summit brand phenolic one inch thick Dominator spacers and try them, one and then two
Page 1 of 4 1 2 3 4
