Another early Hemi question #1369437
01/14/13 02:53 PM
01/14/13 02:53 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I have my 392 Hemi running. Seemed to be running well. The problem that I seem to have is, when I let it sit for a couple of days there is valve train noise on the passenger side for 10 to 15 seconds at initial startup. It then goes away. When I pulled the valve cover the exhaust rockers look to be oiling but the intakes are pretty dry. I pulled the system and checked to see that the shafts and rockers are installed correctly. I blew air through all the passages and get no restriction. I filled the shafts with oil and reinstalled the rockers and still have the same problem. Any ideas?
The first pic is the exhaust rockers that are getting oil. The second pic is the intakes.
Arno
Re: Another early Hemi question [Re: B1arno] #1369438
01/14/13 02:54 PM
01/14/13 02:54 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Intakes
Re: Another early Hemi question [Re: B1arno] #1369439
01/14/13 03:24 PM
01/14/13 03:24 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
If the exhaust shaft is getting oil,but nothing to the intake shaft, then the hole in the intake shaft is not lined up with the oil feed hole in the stand.
Re: Another early Hemi question [Re: TrWaters] #1369440
01/14/13 03:30 PM
01/14/13 03:30 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
That sounds like it could be the problem. I loosened all the rockers and slid them down the shafts to make sure the oil holes and grooves were in the right place. I'm taking it that that does not garantee that the oil hole is lined up in the stand correctly?
Arno
Re: Another early Hemi question [Re: B1arno] #1369441
01/14/13 03:59 PM
01/14/13 03:59 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
If they are stock shafts, check to make sure the holes in the end (where the cotter key would normally go) are straight up and down. Other than that I think you would have to pull the assembly off to take a look at the oil hole alignment.
Re: Another early Hemi question [Re: TrWaters] #1369442
01/14/13 08:27 PM
01/14/13 08:27 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
OK,I pulled the rocker assy to check out the oil hole alignment. The oiling hole is aligned with the rocker shaft. I can see it with a small light and I took my caliper and measured from the base of the rocker stand to the underside of the shaft(see photo). That is 1.230. I then measured from the bottom of the rocker stand down inside the oiling hole and came up with 1.830. By examining the rockers a little closer and looking at TR's photo it appears as though the intake rockers should get oil first. I again shot air through the rocker stand oiling hole and got air from each of the individual intake rockers oiling holes. I'm confused, these things should be oiling unless I'm not getting enough volume coming through. But even then, the intakes should get oil first. Hmmmm. Any other thoughts?
Arno
Re: Another early Hemi question [Re: B1arno] #1369443
01/16/13 04:51 AM
01/16/13 04:51 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
subscribed
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Another early Hemi question [Re: fstfish66] #1369444
01/16/13 10:56 PM
01/16/13 10:56 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I have now checked the rocker assembliy a second time and everything appears in order. The oiling holes are all clear and line up. I then thought that maybe the oiling hole may be misaligned between the rocker stand and the head. After some careful measuring, it appears to be spot on. So now I'm starting to think the issue is farther down in the motor. Maybe a lifter galley plug was left out behind the timing cover? I wouldn't think I would get any oil to the head at that point, or would I? I am getting some. The oiling to the head comes from a cam journal I believe. Maybe the cam bearing is misaligned with the oiling hole? I have never had one of these motors torn all the way down so if any of you has, I'm open to all ideas.
Arno
Re: Another early Hemi question [Re: B1arno] #1369445
01/17/13 12:45 AM
01/17/13 12:45 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've not had an old Hemi torn down, but all the other Mopar motors that oil the rocker shafts through the cam bearing only send oil up through the port once every revolution, when the cam port lines up with the oil port in the bearing.
If the cam bearing was incorrectly installed, the oil hole may be only partially open, which would restrict the amount of oil getting up to the rocker shafts.
What concerns me is that the design of the oil ports in the rocker shaft should oil the upper rocker first, but is not. I bought a new Chrysler 360 block once that only had the oil passage through the block drilled part way. The way I discovered that was on a long trip with the fresh motor, I bent the push rod on either #1 or #8 cylinder (can't remember which). What I thought was oil flow turned out to be oil splash from the cam/ lifter area. Motor had very high idle oil pressure. No oil was coming through the rocker shaft. There was enough splash to lube the rockers around town, but the long highway trip prevented the mostly splash protected rocker on that one cylinder from getting enough lube and tightened up enough to bend the push rod. I had to pull down the motor and finish drilling the oil passage through the block and replace the rocker shaft and the rockers and push rods on that one cylinder.
The reason I wrote all of this is because I want to know if the oil you see on the lower rocker shafts is from the oiling system or oil splash from the cam & lifter area? Pull the rocker shaft, pull the dist, turn the oil pump with a drill and a pre-lube tool, and rotate the motor at least 2 full revolutions. If the oil passages are open, there will be no doubt, oil will shoot out of the passage at oil pressure force. Once fixed, the oil shot out of the oil passage on each side past the front tire on my 35 sedan. I'm betting the oil hole in the cam bearing is not lined up with the oil hole in the block and the oil you are seeing on your lower rocker shaft is from splash.
Sorry Gene
Re: Another early Hemi question [Re: poorboy] #1369446
01/17/13 10:56 AM
01/17/13 10:56 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
The way the hemi head is designed, there are no openings for any splash to enter. There are also no plugs under the timing cover. The cam plate covers the end of the main oil galleys. What kind of oil pressure does the engine have? Is this a hydraulic cam?
Re: Another early Hemi question [Re: TrWaters] #1369447
01/17/13 11:10 PM
01/17/13 11:10 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
As TR says, there is really no way for splash to get up there, so some oil must be making it through. I get 75 lbs when I first start it, and 50lbs warm. It is a hydraulic cam. The ticking noise, when the motor has not been started in a couple of days, made me think that the lifters were not getting sufficent oil, which led me to a possible galley plug missing. I have built a Mopar small block and I forgot the hidden plug under the distributor. Now that makes some noise! I am currently planning on bolting the head on without the rocker assy and priming the pump and spinning the motor again to see how much oil comes out of the oil supply hole. I'm guessing it should shoot out pretty good spinning the pump at 800 rpm. If that looks weak I guess I will be pulling the cam.
Thank you guys for all suggestions!
Arno
Re: Another early Hemi question [Re: B1arno] #1369448
01/18/13 04:33 PM
01/18/13 04:33 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Without the rockers on the head, you might want to run a wire down into the oil supply hole.... to make sure there isnt a head gasket blockage issue.
Re: Another early Hemi question [Re: TrWaters] #1369449
01/18/13 10:35 PM
01/18/13 10:35 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks TR. I neglected to mention that I have done that. A friend also mentioned that there could be a piece of debris or some silicone that may have gotten into the passage and partially blocked it. He suggested blowing air backwards through the oil passage. I think I will remove the oil filter adapter tomorrow and try blowing air from the head through the oil passage and out of the block.
Arno
Re: Another early Hemi question [Re: B1arno] #1369450
01/19/13 06:27 PM
01/19/13 06:27 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Well, I decided to pull the head today. Checked the head gasket alignment. It looked fine. I took a piece of brake line and put it into the oil passage in the block. When it got near the cam it ran into something spongy. My guess is a chunck of silicone. I put my shop vac on it and it was still there. I decided to prime the system with a drill again to see if it would blow out. I spun the motor while priming to get to the proper oiling location and at first oil was just kind of dribbling out of the hole. I rocked the motor back and forth a couple of times and I got a steady stream about 3" tall. I rocked the motor some more and all of a sudden the oil was shooting out 3'. I'm hoping this cleared the blockage. I will put the head back on with the rocker assy and prime the motor again. This will tell me if I now am getting oil to the intake rockers.
Re: Another early Hemi question [Re: B1arno] #1369451
01/19/13 06:51 PM
01/19/13 06:51 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Sounds like you got it.
Moparlee
Re: Another early Hemi question [Re: Robbins] #1369452
01/19/13 09:42 PM
01/19/13 09:42 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
And some day you'll find an oily booger on the other side of the garage wondering where it came from.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Another early Hemi question [Re: 5wndwcpe] #1369453
01/20/13 09:30 AM
01/20/13 09:30 AM
moparx Offline
moparx  Offline
glad you found it arno ! but i would wonder just how many other sillycone boogers are floating around in there and just where did it originate from ? that would bug me a bunch !
Re: Another early Hemi question [Re: moparx] #1369454
01/20/13 03:13 PM
01/20/13 03:13 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Exactly! That will bother me but short of tearing the whole thing down I think that this is the best I can do. As for where it came from, my guess is the oil filter adapter. When I took it off it looked as though they used a bit to much silicone on the gasket. The two oil passages had some silicone squeeze out into them when it was tightened down. I'm thinking some broke off when pressure was sent through the filter. I've cleaned that all up now.
Thanks all for your help. I will let you know what happens when I get it running again.
Arno
Re: Another early Hemi question [Re: B1arno] #1369455
01/20/13 03:26 PM
01/20/13 03:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I almost never use RTV wen I build an engine, you have experience why now. I'll run a file across mating surfaces if need be and spray my gaskets with copper spray if need be. The only places I'll put a tiny bit of RTV is the corners of a multipiece gasket (intake and oil pan).
Don't be the exception.
Re: Another early Hemi question [Re: Supercuda] #1369456
01/26/13 10:17 AM
01/26/13 10:17 AM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Any update?
