Residule Pressure Valve after proportioning valve #1369347
01/14/13 10:45 AM
01/14/13 10:45 AM
Endicott, NY, USA
crazyjjk Offline OP
crazyjjk  Offline OP
Endicott, NY, USA
Redoing brake lines on my 1937 Dodge street rod. It has disc brakes on the front and drums on the back. Can I run the 10 psi residual pressure valve for the back drum brakes after the proportioning valve or does it have to go before it?
Re: Residule Pressure Valve after proportioning valve [Re: crazyjjk] #1369348
01/14/13 11:03 AM
01/14/13 11:03 AM
Andrewh Offline
Andrewh  Offline
I don't think it matters, but typically they are at the master.
Re: Residule Pressure Valve after proportioning valve [Re: Andrewh] #1369349
01/14/13 05:11 PM
01/14/13 05:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
The stock master cylinders had them inside the master cylinder under the brass retaing ferrule in the port the rear brake line fitted in There a little rubber one way flapper valve (it is the stock residual valve) with a tiny coil spring in them
Re: Residule Pressure Valve after proportioning valve [Re: Cab_Burge] #1369350
01/14/13 06:30 PM
01/14/13 06:30 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
You need o get it as close to the master cylinder as possible.
