Valve springs #1369297
01/14/13 12:32 AM
01/14/13 12:32 AM
Silsbee,Tx
-Cuda Offline OP
-Cuda  Offline OP
Silsbee,Tx
What was the specs on factory 906 springs? I have been looking at a Whiplash cam and it has rather high rates.
Re: Valve springs [Re: -Cuda] #1369298
01/14/13 12:54 AM
01/14/13 12:54 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
You'll need different springs. Even if factory springs were the right spring pressure when new,they are very old and weaken with age and use.
Keith
Re: Valve springs [Re: -Cuda] #1369299
01/14/13 04:38 AM
01/14/13 04:38 AM
I'm thinking the HP specs where 95 lbs on the seats and 300 lbs. opended at .484 lift at the retainers I like and use 140 to 175 lbs on the seats and 325 to 375 opened on flat tappet cams, solid or hydraulic lifters. I use 1.6 ratio rockers whenever I can on Mopar BB motors
