Sooo These Bearings Look Good Right??? #1368984
01/13/13 04:44 PM
01/13/13 04:44 PM
western PA
Sb Valiant Offline OP
western PA
Here is a few pictures of our rod bearings..
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368985
01/13/13 04:45 PM
01/13/13 04:45 PM
western PA
western PA
Another
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368986
01/13/13 04:46 PM
01/13/13 04:46 PM
western PA
western PA
Last one
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368987
01/13/13 04:57 PM
01/13/13 04:57 PM
western PA
western PA
While I am at it I mise well put some more pics up for everyone to see..
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368988
01/13/13 04:59 PM
01/13/13 04:59 PM
western PA
western PA
More Pics
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368989
01/13/13 05:14 PM
01/13/13 05:14 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
What was the complaint? Noise? Oil pressure problem??
Re: Sooo These Bearings Look Good Right??? [Re: MPerry] #1368990
01/13/13 05:19 PM
01/13/13 05:19 PM
western PA
western PA
Nothing really other then there was a slight vibration from time to time but my question is these bearings in good shape?
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1368991
01/13/13 05:22 PM
01/13/13 05:22 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
trust me i'm NOT trying to be a smart a$$ but if you have to ask that question you need to enlist the help of an experienced engine builder. those bearings look terrible but at least you took it apart before it did it on it's own
Re: Sooo These Bearings Look Good Right??? [Re: jamesc] #1368992
01/13/13 05:30 PM
01/13/13 05:30 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Just a little clean grease and I'm good right?
Re: Sooo These Bearings Look Good Right??? [Re: jamesc] #1368993
01/13/13 05:31 PM
01/13/13 05:31 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
No... They do not look good.
http://www.bobistheoilguy.com/bearingwear/bearingwearanalysis.htm
.....but good news! I've seen worse!!
Re: Sooo These Bearings Look Good Right??? [Re: J_BODY] #1368994
01/13/13 05:43 PM
01/13/13 05:43 PM
Pa
Hot 340 Online content
Hot 340  Online Content
Pa
J body, not a good analysis if you ask me. Not one metion of the word "timing" or "detonation" in all that, which looks like to OP's main trouble IMO. Also looks like the rod is "rocking".
Re: Sooo These Bearings Look Good Right??? [Re: Hot 340] #1368995
01/13/13 05:46 PM
01/13/13 05:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
That's true, but all I could find for the boy in a few seconds time.... and it does show some valid points in bearing failure.
...and it appears the bottom bearing shell has damage too. Maybe we'll get a pict of that one too.
Re: Sooo These Bearings Look Good Right??? [Re: J_BODY] #1368996
01/13/13 06:31 PM
01/13/13 06:31 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
No, there nasty. About as nasty as u can get before they turn to junk.
To many things to point too but dry startup and too much timing are good starting points lol
Re: Sooo These Bearings Look Good Right??? [Re: FastmOp] #1368997
01/13/13 07:33 PM
01/13/13 07:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Re: Sooo These Bearings Look Good Right??? [Re: rickraw] #1368998
01/13/13 08:22 PM
01/13/13 08:22 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Here is a pic of my bearings. after 300 runs and 1 year. just something to look at and think about.
Re: Sooo These Bearings Look Good Right??? [Re: VernMotor] #1368999
01/13/13 11:13 PM
01/13/13 11:13 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Scuff 'em with scotch brite and run em. Bunch of wimps on here. Vermotor, those are great, Definitely be putting them back in.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Sooo These Bearings Look Good Right??? [Re: Sb Valiant] #1369000
01/14/13 01:35 AM
01/14/13 01:35 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
More Pics
What's this pic of? I can't make it out? BTW, pretty sure it was a sarcastic question by the OP
Re: Sooo These Bearings Look Good Right??? [Re: MoparBilly] #1369001
01/14/13 03:24 AM
01/14/13 03:24 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
I second that.
Not that they look super but was not going to lose a bearing.
Spend $400. And get some better rods recheck bearing clearance.
Clean clean clean that is your best friend in engine building .
Good luck with you project
Re: Sooo These Bearings Look Good Right??? [Re: W5DART66] #1369002
01/14/13 11:36 AM
01/14/13 11:36 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Another good bearing article
http://catalog.mahleclevite.com/bearing/
2011 Drag Pak Challenger
Re: Sooo These Bearings Look Good Right??? [Re: rickseeman] #1369003
01/14/13 12:47 PM
01/14/13 12:47 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I stick to my guns on this one. The top one is marginal but the next two pics show where the top coating is trying to smear and guall along with way to much detonation. I bet if you mic the top bearing its crushed from it. So no it would not be a good idea to reuse those in a hi performance motor.
The other set that Ted posted would be fine to put back in. I have scotchbrited and reused them when they come out looking like his. But the OP's are too far gone. So I still say he needs a set of new bearings and I would check the flatness of the crank and roundness of the rod before reassembly.
Then check your timing mark to make sure it's correct so you can keep the timing correct.
