Re: Edelbrock Heads Question
[Re: BSB67]
#1368953
01/14/13 11:49 PM
01/14/13 11:49 PM
Posts: 10,234 Someplace you aren't
SomeCarGuy
The spot on the outside edge isn't near the bore and has two bolts right there. Looks like a non-issue and I haven't noticed any posts on here about blown gaskets. It's a certainty that a post complaining would be on hee every week if that was a problem with these heads.
I want my fair share
[Re: 500ciDuster]
#1368954
01/14/13 11:55 PM
01/14/13 11:55 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I do recall concerns of this before, and I do see where your talking about.
On my EDDY heads the divot is just over a 1/8" wide. Measuring some of my blocks water ports, if your heads divot is a true 3/8" wide, your correct, that could be a leaker problem. It would seem possible that the water port could overlap the heads divot causing a lack of sealing pressure in that area.
Im measuring a average easy 3/8,s from the edge of the block to the water hole. If your divot is a easy 3/8,s then there will be a slight overlap posible on your set up. To make matters worse, when I put one of my heads on a block I measured, the edge of the head , the side we are talking about, doesnt even extend beyond the blocks outside deck. With your type setup this would make the overlap even worse.
If your setup is truly overlapping then I would say you have a problem. Id go with your epoxy idea, for on the cheap. Welding would require a head shave to true things up, but would be the more correct way to go.
Your heads make me glad that my heads arent even close to what you have. EDDY must be slipping on quality control.
[Re: Clanton]
#1368956
01/15/13 10:28 PM
01/15/13 10:28 PM
Posts: 1,804 McGregor,Iowa 52157
500ciDuster
McGregor,Iowa 52157
Yes that the area that BSB67 posted and mine has a slight overlap into the water passage which is kinda oval shaped on 67 blocks,I could make it go away by decking the heads about .050 We have a scrap yard about 15 miles down the road from my house and sometimes it gets tempting to just pile it all in the back of the truck with the car loaded on the trailer and put all this crap where it really belongs Thanks for the input though! Mitch
[Re: 500ciDuster]
#1368961
01/17/13 01:24 AM
01/17/13 01:24 AM
Posts: 43,313 Bend,OR USA
Cab_Burge
i have several early 440 blocks and several sets of Eddy RPM heads like yours on assemble motors, I'll try and look at one of the early 440 blocks and see if mine(blocks) are like yours or not and if I think there is a issue with the Eddy RPM heads or not ![](/ubbthreads/images/graemlins/confused.gif) I'll post the results tomorrow ![](/ubbthreads/images/graemlins/shruggy.gif) I'm thinking no problems but I'll look and report back anyways ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 500ciDuster]
#1368962
01/17/13 01:59 AM
01/17/13 01:59 AM
Sport440
Canton, Ohio
Is your Divot really 3/8,s wide?? If so, that would place the divots perimeters to about dead center between the two outer head bolt holes. The water holes in the blocks I measured extend that far between the two bolt holes. I have yet to see any Eddy heads divots extend that far. Even the heads you show in your link dont extend that far. Can you show us pics of your heads divots. Do they cross the centerline of the two head bolt holes?? If not you should be good to go. Like I stated earlier, my divots are only a 1/8" wide. that gives me a 1/4" sealing surface at that area. If your heads divot crosses that centerline and your block does too. You may have a problem. Can you go reacess both measurements when you get a chance? ![](/ubbthreads/images/graemlins/thumbs.gif)
