318 poly swap #1368697
01/12/13 11:49 PM
01/12/13 11:49 PM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
hello all this is my first time posting on the forum. I am hoping someone can help me out. I purchased a 66 fury 3 (my first mopar)she has a 318 poly in her. I have learned very quick that it is chore to find parts for this motor So i am looking in to doing a swap, but im not sure what i can drop in it without alot of hastle.I believe it has a torqueflite 727? can anyone confirm this? and what motors will bolt up?
Re: 318 poly swap [Re: tbland09] #1368698
01/13/13 12:21 AM
01/13/13 12:21 AM
NW Pennsylvania
areibel Offline
areibel  Offline
NW Pennsylvania
you shuld be able to swap in any later carburated 318-360 with no problems, I'm pretty sure the bellhousing pattern is the same. And I'm not sure if it's a 727 or a 904, usually the later 318's had a 904 but not sure what they did in 66?
Re: 318 poly swap [Re: areibel] #1368699
01/13/13 01:09 AM
01/13/13 01:09 AM
Andrewh Offline
Andrewh  Offline
all poly 318's had the 727.
it is neutrally balanced.
any small block will bolt up, but only neutrally ballanced motors will bolt up without any extra parts.
for instance the magnum 5.9 bolts up, but you need a special balanced flex plate for it to work, or you need to add weights to the torque converter.
5.2 magnum is neutrally balanced and would bolt right up with the approprate magnum flex plate.
the LA 318 would bolt up with no extra parts.
and you would have 1 bolt hole on the driver side that doesn't line up.
since it is a regular 727 not cable, any 66 and up 727 will bolt up and use the same linkages, so you could take any motor and transmission set and bolt it in. including BB.
just depends on what you are trying to save/keep.
Re: 318 poly swap [Re: Andrewh] #1368700
01/13/13 01:41 AM
01/13/13 01:41 AM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
Thanks for the info guys im just looking for an easy swap to a motor that has more parts availiable and can produce some good power
Re: 318 poly swap [Re: tbland09] #1368701
01/13/13 03:19 AM
01/13/13 03:19 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What parts are you having trouble finding? Stuff like water pumps starters and alternators can be had anywhere as well as plugs and points.
Exhaust manifolds are famous for cracking especially the driver's side, and they are hard to find. If you find a set, take them to a machine shop and have the flanges milled because they are ALL warped and that is what cracks them. If yours aren't cracked do the same so they stay that way.
To answer your question, any LA motor will bolt in but as was posted a 360 will need a special B+M flexplate or a torque converter with a balance weight welded on it because it is externally balanced.
Kevin
Re: 318 poly swap [Re: Twostick] #1368702
01/13/13 07:35 AM
01/13/13 07:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The 66 Charger when the poly blew we put a later LA in.Bolted right up.You might have to go to 67 exhaust pipe as the polys are different.We went headers on the Charger so it didnt matter.Rocky
Chrysler Firepower
Re: 318 poly swap [Re: Twostick] #1368703
01/13/13 11:22 AM
01/13/13 11:22 AM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
@twostick i havent had a problem finding the basic stuff its the performance parts that are i have trouble finding and when i do they are used and a bit pricey
Re: 318 poly swap [Re: tbland09] #1368704
01/13/13 11:26 AM
01/13/13 11:26 AM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
So to drop a la motor in do i need to swap out motor mounts or anything like that?
Re: 318 poly swap [Re: tbland09] #1368705
01/13/13 11:51 AM
01/13/13 11:51 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A good read poly's make great power hardest thing to find is a good aluminum intake since weiand quit making them! Heard some Aussy boys may be casting some soon???
http://www.1962to1965mopar.ornocar.com/poly318.html
http://www.streetlegaltv.com/tech-storie...obody-likes-it/
http://www.moparmusclemagazine.com/howto...er/viewall.html
http://www.moparmusclemagazine.com/techa...ne/viewall.html
Re: 318 poly swap [Re: tbland09] #1368706
01/13/13 11:54 AM
01/13/13 11:54 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hear ya go the most important part you can get everything elese
http://www.ebay.com/itm/1959-1965-MOPAR-...ies&vxp=mtr
someone should buy one of these and have the chinese cast them! :-)
another
http://www.ebay.com/itm/1959-1966-MOPAR-...ies&vxp=mtr
lots of poly stuff polys will really kick but!
http://motors.shop.ebay.com/i.html?_nkw=318+poly
Re: 318 poly swap [Re: Dodgem] #1368707
01/13/13 12:00 PM
01/13/13 12:00 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: 318 poly swap [Re: tbland09] #1368708
01/13/13 01:57 PM
01/13/13 01:57 PM
Andrewh Offline
Andrewh  Offline
318 no. 360 maybe.
one of the mounts is too narrow. you could stack spacers/washers to take up the slack and you would be fine. people do that all the time.
Re: 318 poly swap [Re: Andrewh] #1368709
01/13/13 04:36 PM
01/13/13 04:36 PM
okla.
sam64 Offline
sam64  Offline
okla.
also the right lower bell housing bolt hole will not line up with la motors.it's no biggy just don't waste time tryin to get that bolt to thread in.
Re: 318 poly swap [Re: sam64] #1368710
01/13/13 10:48 PM
01/13/13 10:48 PM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
Thanks for all the help guys
Re: 318 poly swap [Re: tbland09] #1368711
01/14/13 12:11 PM
01/14/13 12:11 PM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
Also, pay attention to which side of the motor your new LA has the lower water pump hose on.
