Re: MP 509 cam ID?
[Re: MPerry]
#1368590
01/13/13 12:53 AM
01/13/13 12:53 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
Is there a way to ID a MP 509 cam visually? I have 2 cams boxed up and I know one of them is a 509.
Not a stinky chance, thanks to Mopars great marketing and sells people I would stick them in a motor and check the cam timing at the lifters That is the only way I know to find out which one is which I had a 383 motor which was suppose to have a Mopar 509 hydraulic cam in it, it turned out to be a 533 hydraulic, I ended up calling Mopar tech to see if there was some paint markings or other was of I.D. the Mopar cams, they said "nope,sorry"
Re: MP 509 cam ID?
[Re: MPerry]
#1368594
01/14/13 01:40 AM
01/14/13 01:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I probably don't even need to go that far now that I think about it. Its going to be the bigger of the 2.
How will you be measuring that???
It will make a difference. It can be determined by some simple measurements though. But sometimes bigger, as you state isnt always bigger.
Re: MP 509 cam ID?
[Re: skrews]
#1368597
01/18/13 09:38 AM
01/18/13 09:38 AM
Posts: 11,657 Fitchburg,Massachusetts
MPerry
Mopahts memba'
Mopahts memba'
Measure the lobe lift. Should be like .339".
Base to tip using a 1-2" micrometer 1.552 base measurement 1.218 1.552-1.218 = .334
Sounds like I have the right cam.
