727 TA Transbrake back to RMVB #1368552
01/12/13 07:21 PM
01/12/13 07:21 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I have a 727 transmission that I modified to run a Turbo Action transbrake. I am going to put a Turbo Action "Cheeta" manual shift, reverse pattern valve body back in. Do I need to undo the changes that were made for the transbrake, or will it be OK to leave them as they are and still run the manual valve body? The changes are a shim in the rear band servo, a plug under the accumalator and blocking a hole in the case under the accumalator, I think.
Thanks,
Brian
Re: 727 TA Transbrake back to RMVB [Re: '72CudaRacer] #1368553
01/12/13 08:25 PM
01/12/13 08:25 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The shim in the rear servo would only make engaging reverse a little harsh (Same feel with the Cheetah tranzbrake). The low/rev band is not used in "1" if you are using the Cheetah RMVB 17156. The accumulator mods should not make any difference using the RMVB. The VBs are basically the same except for the transbrake. I have blocked the accumulator piston down with a rod to firm the 1-2 shift with the Cheetah RMVB.
John
Re: 727 TA Transbrake back to RMVB [Re: DusterW2] #1368554
01/12/13 08:43 PM
01/12/13 08:43 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Run it Brian, the little changes made no difference
in mine with either valve body.
