Trailer bearings.....which grease? #1368541
01/12/13 06:31 PM
01/12/13 06:31 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
What grease do you guys use on your trailer bearings?
Re: Trailer bearings.....which grease? [Re: RV2] #1368542
01/12/13 06:51 PM
01/12/13 06:51 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I always use Black Moly grease on a wheel bearing with drum or no brakes.High temp stuff on disc brake wheels ...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Trailer bearings.....which grease? [Re: RV2] #1368543
01/12/13 06:55 PM
01/12/13 06:55 PM
Locomotion Offline
Locomotion  Offline
I'm kinda partial to Amsoil synthetics and they have a variety of bearing grease as well! I did see less frequent maintenance on my open traler wheel bearings when I switched from conventional grease. I continue to use it on my enclosed trailer. I use the Series 2000 in everything - trailer bearings, car wheel bearings, ball joints, etc.
Amsoil bearing grease.
I also check the wheel bearing and brake adjustments on a regular basis. Good preventive maintenance.
Re: Trailer bearings.....which grease? [Re: Locomotion] #1368544
01/12/13 07:00 PM
01/12/13 07:00 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
for stuff like that i really like the Lucas oils red and tacky. or they also make an hd grease that is green (sorry can't remember the name)
Re: Trailer bearings.....which grease? [Re: RV2] #1368545
01/13/13 12:47 AM
01/13/13 12:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
A good brand of high temp heavy duty black moly wheel bearing grease
Re: Trailer bearings.....which grease? [Re: Cab_Burge] #1368546
01/13/13 12:55 AM
01/13/13 12:55 AM
Dyno1 Offline
Dyno1  Offline
Mobil 1 synthetic.
Re: Trailer bearings.....which grease? [Re: Dyno1] #1368547
01/13/13 01:29 AM
01/13/13 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mobil 1 synthetic.
This is what I use.... but the supplier gave me a case
BUT its been working well on my rig... I clean and
hand pack them every 2 years but I have the buddy bearings
so I grease them when the cups start getting low...
never had to replace any bearings YET... on any of
the 11 trailers I own
Re: Trailer bearings.....which grease? [Re: prochargedhemi] #1368548
01/13/13 11:42 AM
01/13/13 11:42 AM
Indiana
79_W200 Offline
79_W200  Offline
Indiana
1979 W200 470
Re: Trailer bearings.....which grease? [Re: Dyno1] #1368549
01/13/13 03:42 PM
01/13/13 03:42 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Mobil 1 synthetic.
I also use it on my travel trailer and have never had a bearing failure. I inspect the bearings every 2 years and they always look good.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
