Undercoat touch up. #1368456
01/12/13 04:05 PM
01/12/13 04:05 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Forgive me if this has discussed but as I was applying the Rust-oleum roll on bed coating for my truck,it occurred to me that this may be a good substitute for the few spots of the factory coating that I blasted off on the underside of my Charger. I had thought of the 3m rocker panel texture as well.The inside of my wheel wells could use some as well. I did not want to go to the trouble of the full blown undercoating job that would be in order for a restoration. It only needs a few spots. Any thoughts?
Re: Undercoat touch up. [Re: fastmark] #1368457
01/12/13 04:59 PM
01/12/13 04:59 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
That is what I used on my satellite. It was undercoated, and I wanted same kinda thing, and thought the bed liner stuff would be tougher than the old style stuff . . . went on easy and looks good !!!
Re: Undercoat touch up. [Re: a12rag] #1368458
01/12/13 07:39 PM
01/12/13 07:39 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
used the same for touch up, i did use a wire brush to just dab the tacky stuff and blended perfectly. did this on a practice piece first
