Tips to make a roller cam live on the street? #1368384
01/12/13 10:36 AM
01/12/13 10:36 AM
Toronto (YYZ) Ontario
YYZ Offline OP
YYZ  Offline OP
What are current 'best practices' to ensure a long, reliable life for a solid roller cammed big block?
Aside from a high-quality bronze drive gear and adjustable rockers....
Car will be driven 95% street and 5% strip
Thanks in advance!
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368385
01/12/13 12:01 PM
01/12/13 12:01 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
just had my "race" engine re-built as a street pump gas engine..
had the Comp Cams Roller re-ground (smaller) and the com cams roller lifters are their HD ones....
the engine's first pull was about 670hp with over 650 lbs.ft....was rich and still climbing past the 7200rpm that is was shut off....so with a good tune and some break in, it should be a 700+hp pump gas engine and live well on the street..
Midwest Engine Tech built my engine..if you want the specs, and if they are will to give them to you, give them a call..ask for Scott..
1-815-464-9490..Mokena,Illinois
some specs...499"
kept the Indy 440-3X intake..would make more tork with a smaller one
Holley HP 4500/1050 Dominator
Bulldog Heads that flow
JE dished pistons for 10-1 compr
Eagle 4.15 crank
Eagle H-Beam rods
Jessel belt drive
Erson 1.6 roller rockers
lower end balanced
Doug's fender well exit headers w/2" primaries into 3 1/2" collectors
forgot...billet steel main caps
stud girdle
Milodon dual pickup/oil pump
Milodon modified drag pan
MSD Billet Distr locked out @36*
is this good enough??..
Re: Tips to make a roller cam live on the street? [Re: smokinwoody] #1368386
01/12/13 01:00 PM
01/12/13 01:00 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I just kept the idle RPM up to atleast 1500rpm and never had any problem. I always heard keep the idle a little higher then normal and it would keep oil splashed around and make it live. I dont know how true that is.
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368387
01/12/13 01:24 PM
01/12/13 01:24 PM
gregsdart Offline
gregsdart  Offline
High idle rpm, or lifters that oil the roller wheel bearings.
Re: Tips to make a roller cam live on the street? [Re: gregsdart] #1368388
01/12/13 01:34 PM
01/12/13 01:34 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
When I had a cam made up for my motor I called Bullet cams. I told them it would see 95% street driving and wanted a solid roller with some lobes that didn't beat the valvetrain to death. I turn wrenches for a living and don't want to be changing valve springs everytime I turn around.
I couldn't be happier, it may be down a couple hp but it's next to zero maintanence.
The cam specs are .767/.676, 288/292@.050 on a 113 center. I have the idle set at about 1200rpm.Dave
Re: Tips to make a roller cam live on the street? [Re: quickd100] #1368389
01/12/13 01:56 PM
01/12/13 01:56 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i never understood everyone running a crazy idlespeed because of rollercams. my solidroller smallblock has never had its idle higher than 8-900rpm and no problems with it at all, barely left idle for a loooooooong cruice night over 8hours and didnt see any trouble from it that time either.
just keep an eye on springpreasure and you will be fine for a long time.
Re: Tips to make a roller cam live on the street? [Re: 1Fast340] #1368390
01/12/13 04:48 PM
01/12/13 04:48 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I think the high idle is something the chevy boys have had to come up with to keep there junk alive.
I have two street cars with solid roller cams, a BB mopar and a SB mopar and both are doing great.
My 440 has appox. 2500 miles on it and the SB has over 5000 street miles and appox. 40 1/4 passes at the drag strip.
I drive the SB car back and forth to work[24 mile round trip] I have made a round trip to Vegas and back and last September I did Hot Rod dragweek.
This summer I hope to make a 6000 mile trip with the SB car.
Make sure you buy very good lifters,valve springs,and rockerarms.
Re: Tips to make a roller cam live on the street? [Re: Darryls-Demon] #1368391
01/12/13 05:01 PM
01/12/13 05:01 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I had a sb with almost exactly the same amount of miles. Sold the motor, but lifters were still in great shape as well as springs. Guides were still okay as well.
Re: Tips to make a roller cam live on the street? [Re: viperblue72] #1368392
01/12/13 05:07 PM
01/12/13 05:07 PM
Guitar Jones Offline
The secret tip? Drive it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368393
01/12/13 06:14 PM
01/12/13 06:14 PM
The key to make a solid roller cam live on the street is to use more spring pressure than needed to start with, it will lose some, and buy rhe best solid roller lifters you can get And plenty of oil, pressure oil to the rollers and axles is preffered I had two of the Mopar brand solid roller lifters break the wheels in half, I swapped them out after the second one I have Crowers Ultra liftes in one motor, Bullits in another motor and two sets of Crane race (best ones they sell) lifters on the shelf. I also have a set of the Comp Camd AMC lifters for oiling through the pushrods for a motor that will have a set of Jesel rocker arms that require either spray bar oiling or pushrod oiling, or both Buy the best oil you can get also and change two or three times a year, cut the filters apart and look for debris Check the lifters at the end of each year, take them all out and feel the rollers for roughness, replace or have them rebuilt when rough Another thing is the roller wheel diameter, buy the big ones
Re: Tips to make a roller cam live on the street? [Re: Cab_Burge] #1368394
01/12/13 08:30 PM
01/12/13 08:30 PM
YYZ Offline OP
YYZ  Offline OP
Is bushing the lifter bores required, or not crucial with the modern solid rollers with oiling provisions?
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368395
01/12/13 10:41 PM
01/12/13 10:41 PM
Glendale Az
Glendale Az
My BB is bushed but the SB is not.
Re: Tips to make a roller cam live on the street? [Re: Darryls-Demon] #1368396
01/12/13 11:10 PM
01/12/13 11:10 PM
V
viperblue72 Offline
viperblue72  Offline
V
The modern roller lifters don't require bushed lifter bores.
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368397
01/12/13 11:19 PM
01/12/13 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The block I have in my street rod/drag week car is
not bushed... I have it idling at 800 but I went with
the EDM hole on the lifters to supply added oil to
the roller... I believe I will UP the spring pressure
by another 30# to give me 280# on seat... I think its
starting to bound the lifters at 6700 rpm(with 250#)
but it could just be the cam ran out
Re: Tips to make a roller cam live on the street? [Re: MR_P_BODY] #1368398
01/13/13 10:23 AM
01/13/13 10:23 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Good info guys....
Hey quickd/Dave, what are your seat pressures and psi on the nose?
What brand of spring are you running with that bullet roller?
Just wondering how it compares to mine spring wise?
Thanx !!
Re: Tips to make a roller cam live on the street? [Re: LAD 524] #1368399
01/13/13 10:53 AM
01/13/13 10:53 AM
YYZ Offline OP
YYZ  Offline OP
Cool - great advice so far, thanks.
So for rocker arms, which are considered to be the best for longevity?
Aluminum arms such as Crane Gold, Harland-Sharp etc. or go to a steel arm such as Comp Cams?
Is there anything special that has to be done to control thrust on the camshaft (special thrust buttons etc) or just bolt it in?
Re: Tips to make a roller cam live on the street? [Re: LAD 524] #1368400
01/13/13 12:07 PM
01/13/13 12:07 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Good info guys....
Thanx !!
I'm using K Motion 950's, 245 on the seat (2.00), [Email]720@1.250.[/Email] I know some people don't like these springs but they've been holding up fine for me. Of course I don't have to rev the motor to the moon either, hp peak is at 5800rpm (605ci). Valve train is supposed to be stable to 7800, I had my 528ci up there a couple times. I could get my 605 to idle around 1000rpm easily but what's 200 rpm.Dave
Re: Tips to make a roller cam live on the street? [Re: quickd100] #1368401
01/13/13 02:00 PM
01/13/13 02:00 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just put some miles on my first roller setup. I have comp 828 lifters, erson rockers, and K-800 springs. I put about 2500 miles on it over a year and 1500 of them were on drag week. I just recently tore it down and everything looked really good. The roller wheels all roll smooth and free and I am putting them back in.
The kicker with mine is that the oil is blocked off to the lifters so they just oil off of the drain back from the rockers. I keep my idle at 1000-1200 and the rockers oil full time so there is plenty of oil up there. I was a little nervous about how it would look on tear down but the valvetrain all looked great.
Did this for 5 days
68 Barracuda Formula S 340
Re: Tips to make a roller cam live on the street? [Re: YYZ] #1368402
01/13/13 03:00 PM
01/13/13 03:00 PM
Glendale Az
Glendale Az
The best rocker arms are something like jesel pro steel rocker arms but as far as I know they do not sell them for BB mopars.
T&D or jesel makes a good Aluminum rocker.
Yes you will need a cam button and it is a good idea renforce the timing chain cover.
Re: Tips to make a roller cam live on the street? [Re: Darryls-Demon] #1368403
01/13/13 04:17 PM
01/13/13 04:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Don't use the comp steel rockers with a roller cam.
