carb paint removal #1367892
01/11/13 12:17 PM
01/11/13 12:17 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
What is the best method to remove paint off a carb? Just received a carb for a 38 dodge that someone thought would look better if it was painted. What is the best way to remove the paint from the carb
Re: carb paint removal [Re: TrueTripleX] #1367893
01/11/13 12:26 PM
01/11/13 12:26 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
spray brake cleaner.
Re: carb paint removal [Re: bonefish] #1367894
01/11/13 02:01 PM
01/11/13 02:01 PM
Ball Ground GA
Ball Ground GA
Just a question but would soaking the carb in acetone damage the body or other parts of the carb?
Re: carb paint removal [Re: TrueTripleX] #1367895
01/11/13 03:06 PM
01/11/13 03:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Acetone won't harm the carb hard parts but it can do a number on gaskets and soft parts. If you are rebuilding it you can use Acetone no problem, if not I'd suggest less aggressive chemicals.
