What Dist Gear With Lunati Solid Roller? #1367783
01/11/13 12:14 AM
01/11/13 12:14 AM
SE PA
Yellow Fever Offline OP
SE PA
Nothing on their website and I sent an email but still waiting for an answer. Does anybody know if you can run a stock dist gear on a BB with the Lunati Solid Roller?
Re: What Dist Gear With Lunati Solid Roller? [Re: Yellow Fever] #1367784
01/11/13 12:27 AM
01/11/13 12:27 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Absolutely not! Bronze gear ONLY.
Re: What Dist Gear With Lunati Solid Roller? [Re: Stanton] #1367785
01/11/13 12:50 AM
01/11/13 12:50 AM
SE PA
SE PA
Ok. I've read elsewhere that they press an iron gear on their cams but if you know first hand.
Re: What Dist Gear With Lunati Solid Roller? [Re: Yellow Fever] #1367786
01/11/13 12:56 AM
01/11/13 12:56 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have seen solid rollers like that. I would call Lunati and ask them.
Re: What Dist Gear With Lunati Solid Roller? [Re: Jeremiah] #1367787
01/11/13 01:05 AM
01/11/13 01:05 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There is also a Comp Cams (?) composite gear...
Re: What Dist Gear With Lunati Solid Roller? [Re: Stanton] #1367788
01/11/13 05:59 AM
01/11/13 05:59 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What about the new crane cams that is a steel gear for roller cams?
Re: What Dist Gear With Lunati Solid Roller? [Re: Yellow Fever] #1367789
01/11/13 10:18 AM
01/11/13 10:18 AM
scratchnfotraction Offline
my SB lunati 60710 voodoo hydro roller cam uses the stock intermed shaft. has the iron ring on the cast cam core.
if the solid roller cam is billet it will need the bronze gear.
if it is a cast core or has the ring it can use the stock gear from my understanding after talking to lunati tech line.
I also went with a comp 901-16 spring, single with damper over there doubles with a damper. has the same spring rate specs with no machine work to install them.
Re: What Dist Gear With Lunati Solid Roller? [Re: scratchnfotraction] #1367790
01/11/13 08:43 PM
01/11/13 08:43 PM
SE PA
SE PA
Well Lunati said bronze or composite but I can't find a composite gear anywhere. Now I'm deciding between a hyd roller or a solid roller? Mostly street use so..........
Re: What Dist Gear With Lunati Solid Roller? [Re: Yellow Fever] #1367791
01/12/13 10:06 AM
01/12/13 10:06 AM
PA
noplanb Offline
noplanb  Offline
PA
Hughes sells a coated gear that replaces bronze
http://www.hughesengines.com/Index/produ...mp;partid=26734
And if its mostly street, do yourself a favor and go juice. Getting inside the valve covers every year's just gonna give you oil leaks and a sore back.
remember when you said honey, some day that car is gonna look so good in front of our house
