Re: How do you fix a fiberglass hood that is warped?
[Re: Jonnyj00]
#1367510
01/10/13 04:38 PM
01/10/13 04:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If the Duzs fasteners will be in the area to hold it down then just do that.... or you can glass on reinforcements in those areas... fiberglass is a PITA when its in the sun and tends to move around... I made a glass hood but got fed up with it moving so I used the same mold and made a carbon fiber hood... that stuff is great
[Re: MR_P_BODY]
#1367511
01/10/13 05:36 PM
01/10/13 05:36 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
You can add bracing to it but it was probably a junk hood to start with.
[Re: Dodgeguy101]
#1367513
01/10/13 07:31 PM
01/10/13 07:31 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I tend to agree with this statement. A properly made fiberglas product will retain its shape even in hot sun (Corvettes !!!). This was likely made with no lips on the edges or any support to speak of so it was just like a piece of paper - free to flex as it pleased. Even being taken out of the mold too soon would have an adverse affect. There are still cheapo hoods and other products being made and sold today as "lightweight". However, a quality manufactured product can still be light and structurally stable.
[Re: Stanton]
#1367514
01/10/13 08:03 PM
01/10/13 08:03 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Propane torch. You will ruin the paint and maybe even the gel-coat in spots if you aren`t REAL careful. Heat from underside as even as you can an area no more than a square foot or so at a time. When it starts smoking, weight/ hold untill cool enough to touch. After you get it where you want it then add a bow or brace. I use thin-wall tubing or 5/16th rod. I`ve straighten some really nasty/cheap glass parts like this. Still looks good 20yrs later
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Guitar Jones]
#1367515
01/10/13 08:24 PM
01/10/13 08:24 PM
MR_P_BODY
What I am talking about for bracing is fiberglass tubing... I usually split it length ways and glass that to the hood once you get it back into shape... usually 3/4" or 1" fiberglass tubing(sold at any fiberglass suppliers).... just because its a light weight hood doesnt make it junk
[Re: MR_P_BODY]
#1367516
01/10/13 08:37 PM
01/10/13 08:37 PM
Posts: 912 London, England
mopar_mark
London, England
I would fix the hood to the car, with intended Dzus clips or fasteners. If shape is still not correct you can either force down with weights or even use a long self tapping screws.
Then apply heat to the hood with a hot air gun, just get the hood warm, you don't need to get so hot that it removes or burns the paint.
You will have more success with a newer glassed hood than an old one, as glass is still malleable for a while. After heating, leave hood in place for a couple of days to settle. Assuming hood is maintaining the shape you want, you can glass in some supports.
Carbon fibre (CF) hoods are great, just ensure the mould which the CF hood is to be taken from, fits your car perfectly, as CF does not move, has zero flexibility, unless it paper thin. . .
[Re: dOc …]
#1367520
01/11/13 12:56 AM
01/11/13 12:56 AM
MR_P_BODY
aLmost furrgot ...and to youz-guyz with the heat-gunz ....
The sun is all you need... it moved it before... it'll move it again... and when its in place then cool it in that location.... then brace it... been there... done that
[Re: Jonnyj00]
#1367523
01/11/13 01:56 AM
01/11/13 01:56 AM
MR_P_BODY
Thanks for the ideas guys!
I thought a little about building something that mounted to the carb that could possibly hold the hood up in the middle and force the air down the carb better. Would this work or could too much air be a problem?
Think of it this way.... you can never force enough air down that carb.. a forward scoop in the right location acts as a really small super charger but without the belt(its pressure)... but the carb needs to be sealed to the scoop... plus with the scoop sealed off it doesnt allow the hot air from the engine bay into the carb
[Re: MR_P_BODY]
#1367524
01/11/13 04:40 AM
01/11/13 04:40 AM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
Thanks Mr. P! your advice has always steered noobs like me in the right direction! Thanks again to everybody else as well! I think I will try and construct something rigid to catch air and hold up the center of the hood all at the same time. Its a 6 pack scoop so it has a pretty wide opening but I will think of something I'm also gonna flip the hood up side down and put some weight in the middle on 2 sawhorses I believe that will help. The biggest trick will be constructing something to hold the hood up that isn't gonna be too heavy...
