How do you fix a fiberglass hood that is warped? #1367509
01/10/13 04:20 PM
01/10/13 04:20 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I have a race weight fiberglass hood for my demon that came with the car when I bought it and it has a problem where the back corners are pointing up and the scoop is down lower than it should be. Is there any way to reshape this hood or will i have to build something that will hold it in the correct position from underneath. I plan on using some of the dz fasteners around the edge to hold that in place but the actual scoop will still be lower than it should.
Re: How do you fix a fiberglass hood that is warped? [Re: Jonnyj00] #1367510
01/10/13 04:38 PM
01/10/13 04:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the Duzs fasteners will be in the area to hold it
down then just do that.... or you can glass on reinforcements
in those areas... fiberglass is a PITA when its in
the sun and tends to move around... I made a glass
hood but got fed up with it moving so I used the same
mold and made a carbon fiber hood... that stuff is great
Re: How do you fix a fiberglass hood that is warped? [Re: MR_P_BODY] #1367511
01/10/13 05:36 PM
01/10/13 05:36 PM
Guitar Jones Offline
You can add bracing to it but it was probably a junk hood to start with.
Re: How do you fix a fiberglass hood that is warped? [Re: Guitar Jones] #1367512
01/10/13 06:22 PM
01/10/13 06:22 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Mine sat on the car on and off in the sun for 20 years, the weight of the hood scoop had it bowed down. I turned the hood upside side, put a little weight on it after a week or so, I put some reinforcing sheets of fiberglass across it. Works great now. The edges if you just lay something heavy on them, they will go back down to where you them, or close anyway.
At least worth a try.
Re: How do you fix a fiberglass hood that is warped? [Re: Dodgeguy101] #1367513
01/10/13 07:31 PM
01/10/13 07:31 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I tend to agree with this statement. A properly made fiberglas product will retain its shape even in hot sun (Corvettes !!!). This was likely made with no lips on the edges or any support to speak of so it was just like a piece of paper - free to flex as it pleased. Even being taken out of the mold too soon would have an adverse affect. There are still cheapo hoods and other products being made and sold today as "lightweight". However, a quality manufactured product can still be light and structurally stable.
Re: How do you fix a fiberglass hood that is warped? [Re: Stanton] #1367514
01/10/13 08:03 PM
01/10/13 08:03 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Propane torch. You will ruin the paint and maybe even the gel-coat in spots if you aren`t REAL careful.
Heat from underside as even as you can an area no more than a square foot or so at a time. When it starts smoking, weight/ hold untill cool enough to touch.
After you get it where you want it then add a bow or brace. I use thin-wall tubing or 5/16th rod.
I`ve straighten some really nasty/cheap glass parts like this. Still looks good 20yrs later
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: How do you fix a fiberglass hood that is warped? [Re: Guitar Jones] #1367515
01/10/13 08:24 PM
01/10/13 08:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I am talking about for bracing is fiberglass
tubing... I usually split it length ways and glass
that to the hood once you get it back into shape...
usually 3/4" or 1" fiberglass tubing(sold at any fiberglass
suppliers).... just because its a light weight hood
doesnt make it junk
Re: How do you fix a fiberglass hood that is warped? [Re: MR_P_BODY] #1367516
01/10/13 08:37 PM
01/10/13 08:37 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I would fix the hood to the car, with intended Dzus clips or fasteners. If shape is still not correct you can either force down with weights or even use a long self tapping screws.
Then apply heat to the hood with a hot air gun, just get the hood warm, you don't need to get so hot that it removes or burns the paint.
You will have more success with a newer glassed hood than an old one, as glass is still malleable for a while. After heating, leave hood in place for a couple of days to settle. Assuming hood is maintaining the shape you want, you can glass in some supports.
Carbon fibre (CF) hoods are great, just ensure the mould which the CF hood is to be taken from, fits your car perfectly, as CF does not move, has zero flexibility, unless it paper thin. . .
Re: How do you fix a fiberglass hood that is warped? [Re: mopar_mark] #1367517
01/10/13 09:28 PM
01/10/13 09:28 PM
Florida STAYcation
MasterDeBaTeR ! Online penguin-006
The village idiot's idiot
MasterDeBaTeR !  Online Penguin-006
Florida STAYcation
Post a pic of the underside bracing ... I will bet that what you have there is uNsufficent. Putting-in better bracing is not a big deal though.
Re: How do you fix a fiberglass hood that is warped? [Re: MasterDeBaTeR !] #1367518
01/10/13 09:44 PM
01/10/13 09:44 PM
Florida STAYcation
Florida STAYcation
aLmost furrgot ...and to youz-guyz with the heat-gunz ....
Re: How do you fix a fiberglass hood that is warped? [Re: MasterDeBaTeR !] #1367519
01/11/13 12:35 AM
01/11/13 12:35 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Never had any success with heat.
Re: How do you fix a fiberglass hood that is warped? [Re: MasterDeBaTeR !] #1367520
01/11/13 12:56 AM
01/11/13 12:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The sun is all you need... it moved it before... it'll
move it again... and when its in place then cool it
in that location.... then brace it... been there...
done that
Re: How do you fix a fiberglass hood that is warped? [Re: MR_P_BODY] #1367521
01/11/13 01:07 AM
01/11/13 01:07 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thanks for the ideas guys!
I thought a little about building something that mounted to the carb that could possibly hold the hood up in the middle and force the air down the carb better. Would this work or could too much air be a problem?
Re: How do you fix a fiberglass hood that is warped? [Re: Dodgeguy101] #1367522
01/11/13 01:51 AM
01/11/13 01:51 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
This is how most if not all boat manufactures fix molds when they distort,Ive fixed many glass pannels myself with this method!!
Re: How do you fix a fiberglass hood that is warped? [Re: Jonnyj00] #1367523
01/11/13 01:56 AM
01/11/13 01:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Think of it this way.... you can never force enough
air down that carb.. a forward scoop in the right
location acts as a really small super charger but
without the belt(its pressure)... but the carb needs
to be sealed to the scoop... plus with the scoop sealed
off it doesnt allow the hot air from the engine bay
into the carb
Re: How do you fix a fiberglass hood that is warped? [Re: MR_P_BODY] #1367524
01/11/13 04:40 AM
01/11/13 04:40 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Thanks Mr. P! your advice has always steered noobs like me in the right direction! Thanks again to everybody else as well!
I think I will try and construct something rigid to catch air and hold up the center of the hood all at the same time. Its a 6 pack scoop so it has a pretty wide opening but I will think of something
I'm also gonna flip the hood up side down and put some weight in the middle on 2 sawhorses I believe that will help. The biggest trick will be constructing something to hold the hood up that isn't gonna be too heavy...
Re: How do you fix a fiberglass hood that is warped? [Re: Jonnyj00] #1367525
01/11/13 06:02 AM
01/11/13 06:02 AM
Florida STAYcation
Florida STAYcation
TWO Q's 4 U .....do you have a pic of the uNderside of the hood? .. do you have a stock steel hood available ?
Re: How do you fix a fiberglass hood that is warped? [Re: MasterDeBaTeR !] #1367526
01/11/13 01:37 PM
01/11/13 01:37 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I don't have a pic of the underside of the hood right now but I could get one. I do have a steal hood though why do you ask?
Re: How do you fix a fiberglass hood that is warped? [Re: Jonnyj00] #1367527
01/11/13 02:20 PM
01/11/13 02:20 PM
Florida STAYcation
Florida STAYcation
IF you have a steel hood ... you can make a wood "form"(from the contours of the steel hood) out of 1x3 firring strips ...and then use that on the REbracing of the glass hood.
Re: How do you fix a fiberglass hood that is warped? [Re: MasterDeBaTeR !] #1367528
01/11/13 08:08 PM
01/11/13 08:08 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
What would you know??
If you like drag racing, support your local track.
