Hemi guys - who make a 1/2" drive apaptor for.... #1367268
01/10/13 07:44 AM
01/10/13 07:44 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
The valley studs?
Id rather have the right tool for the job - can anyone tell me where I can source one?
Thanks !!
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: LAD 524] #1367269
01/10/13 08:24 AM
01/10/13 08:24 AM
pa
572charger Offline
572charger  Offline
pa
mine is a matco but i think snapon makes them also
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: 572charger] #1367270
01/10/13 09:41 AM
01/10/13 09:41 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Mac tools.
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: B G Racing] #1367271
01/10/13 09:49 AM
01/10/13 09:49 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanks guys anyone got any part #?
The nuts are 1/2" from memory right?
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: LAD 524] #1367272
01/10/13 11:31 AM
01/10/13 11:31 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The adapters I have are 3/8. And there are 2 sizes of nuts depending on the supplier.
2011 Drag Pak Challenger
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: rickseeman] #1367273
01/10/13 01:46 PM
01/10/13 01:46 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Original factory nuts are 5/8ths", most aftermarket style (KB's and others are 1/2" twelve points.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: LAD 524] #1367274
01/10/13 04:33 PM
01/10/13 04:33 PM
Snap On and Mac make them(offset crow feets, not the proper name ) in 3/8 drive, I ended up buying the 1/2,9/16 and 5/8 to cover all the different size nuts used on all the different the Hemiriod motor fasteners used out there. I have had to grind off some of the metal on the back side(valley side) on two of them You will need to do the math on the length of the extension to be able to set the proper torque value on your wrench before tightening the inner nuts I bought a 3/8 drive inch lb wrench that goes as high as 750 inch lbs, I use it for the inner nuts only, IE 56 lbs x 12 inch lbs =672 inch lbs setting on that wrench
Re: Hemi guys - who make a 1/2" drive apaptor for.... [Re: Cab_Burge] #1367275
01/10/13 05:42 PM
01/10/13 05:42 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Check the mcmaster Carr industrial catalog and save some money! Less then $20.00 when I bought mine 2 yrs ago
