distance between frame connectors on an e body? #1366745
01/08/13 09:25 PM
01/08/13 09:25 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
For my winter project I'm back halfing an e body with a competition engineering ladder bar kit, rear cross member and frame rails. I'm was wondering how far apart are the frame connectors going to the front cross member generally?
Re: distance between frame connectors on an e body? [Re: Jonnyj00] #1366746
01/08/13 09:48 PM
01/08/13 09:48 PM
organ
maximum entropy Offline
organ
i know on sea bodies it's ~36 feet.
Re: distance between frame connectors on an e body? [Re: maximum entropy] #1366747
01/09/13 03:57 PM
01/09/13 03:57 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
I ended up putting them 32.5 in. apart. After I posted this my uncle talked to a chassis guy in the area that said you want them as close as you can without interfering with the tranny. So I put them about a inch and a half outside the torsion bar sockets.
