Re: Looking at a new aftermarket wiring harness, opinions?
[Re: ryanf]
#1366433
01/09/13 12:51 AM
01/09/13 12:51 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I've used hotrod style harnesses & I've used stock harnesses, 95% of the time I would use the stock harness... Most cars I suggest a OE harness but I add relays to run high draw components like the headlights & blower motor taking the load off the original switches, connectors & wiring while supplying full power to the components....
[Re: Ramrod39]
#1366435
01/09/13 03:12 AM
01/09/13 03:12 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I've used a few M & H harnesses and have alway been pleased with them.
I agree . There's nothing like having everything fit correct with all new plugs. M&H cost more but you get good quality
When you have the cluster out & are hanging the harness to the bottom of the dash frame. the tangs line up with the loops perfect & ALL of the wires are the correct length & color as factory. The other guys you need a wiring diagram for GM to figure out
[Re: ryanf]
#1366436
01/09/13 07:35 AM
01/09/13 07:35 AM
Posts: 11,082 Berlin, N.J.
abodyjoe
Berlin, N.J.
Well, my car(74 swinger) is supposed to be back from the painter at the end of this month so i am looking at what wiring harness would be a good choice. Right now i am looking at the kwik wire
http://stores.homestead.com/ez2wire/-strse-38031/AMC-Jeep-Chevy-Chevrolet/Detail.bok
and the American Auto wire http://www.americanautowire.com/highway22.html
Any opinions? others i should be looking at? Looking to have a decent sound system, EFI, electric fan, eventually power doors.
Thanks Ryan
go with the american autowire highway22 kit.. you wont be sorry. it will handle anything you want to throw at it.. stay away from that cheap crap.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#1366439
01/09/13 11:50 PM
01/09/13 11:50 PM
Posts: 54 SW Iowa
gearhead452
SW Iowa
I'm sure most any of the kits mentioned above would work great! I put a Painless Wiring Universal Mopar harness (P/N 10127) in a '68 b-body this past summer. Here's couple of things I can share about how that went: If you want it to look stock don't get this kit (sounds like this probably doesn't matter), as it does away with the multi-pin connector at the firewall. The kit also uses an 80 amp maxi-fuse between the alternator and the harness. The kit is designed for a stock style Mopar alternator. You'll have some extra wires if you want to run a one wire alternator. The Painless Mopar harness is colored coded with the factory Chrysler colors and the the kit includes the factory style wire connectors. These need to be installed by you, with a crimper using the existing plastic portion of your plug in connectors - so the factory plug in connectors are retained. The crimp connectors are very difficult to install if you do not have the correct crimping tool (I didn't). Each wire is also coded by number and has the name of the connection printed on it - maybe all these kits have that, it is extremely nice! The instructions with this kit are specific to a Mopar, and are not for a "universal" installation. which is nice. However, the dash portion and steering column portions of the harness are designed for a '71 and up Mopar (the kit is designed to retain the stock dash). The dash and steering column connections are close for other years but not exact. I had a schematic of the factory harness and was able to figure out the dash and column, but it took me forever! Good luck with whichever one you pick!
2012 Hot Rod Drag Week, Street Race BB/NA, 4th Place.
