Windhield wiper arms came off the linkage, thoughts?
#1366316
01/08/13 12:06 PM
01/08/13 12:06 PM
Mud Pig
I knew what I was getting into buying a classic truck, given my experience with a 66 mustang I use to own. I replace one thing and another thing breaks. Its a process before you get the classic stabilized and in good working order. So here is the latest issue. I replaced the windshield wipers with new blades. I was riding down the road and got something on the windshield, hit the wiper fluid button and then I tried turning on the wipers. They certainly worked before I replaced the blades. Nothing came on while I was driving. I get home and try to figure out what is going on, low and behold the wiper arms came off the linkage that connects to wiper motor. You can see the motor spinning the linkage arm around and around, the wiper arms just aren't connected anymore and are laying in the panel.
So from the looks of it I need to take off the vent panel right behnd the hood to access the motor and linkage arms. Now my question is, do I need some parts to put it back together. I'm assuming a bushing, cotter pin, etc.. broke. Before I take it apart I'd like to get the parts I need.
This is on a 1976 Dodge D-100 Warlock. Thanks.
Re: Windhield wiper arms came off the linkage, thoughts?
[Re: Mud Pig]
#1366317
01/08/13 12:12 PM
01/08/13 12:12 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
99% of the time, it's the nylon bushings on the wiper linkage. you can get these pretty cheap at your local parts store in the Help section. you'll need a couple of packs(2 bushings in each). Pull the wiper arms, take off the cowl, and you'll see which arm cam off. replace all the bushings. I put a touch of oil in the bushings, and used channel locks to put the arms back on.
1981 Dodge D150 360 auto
[Re: basketcase]
#1366318
01/08/13 12:31 PM
01/08/13 12:31 PM
Mud Pig
Thanks, that's what I needed to know. I'll go check with Advanced autoparts tonight. Any chance you know the part number?
[Re: Mud Pig]
#1366319
01/08/13 01:07 PM
01/08/13 01:07 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I just replaced the 1s on my shorty. I got mine at O'Riellys. They were in the "HELP" section.. Replace all 3 while your in there. Soak them in hot water before intalling them. Makes the job a lot easier.
I am truckless..
[Re: 340SHORTY]
#1366323
01/09/13 02:07 AM
01/09/13 02:07 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Yes, expect some loss of skin, and some use of four letter words. I used PB blaster to help get the metal tray back under the windshield gasket, white grease on the new plasic cups and small channel locks to lock them together. Napa had them in stock...
[Re: basketcase]
#1366325
01/09/13 01:50 PM
01/09/13 01:50 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
i wouldnt use oil myself, it will let them pop off later, and might even break down the plastic. use some plastic compatible stuff, like lithium or graphite. if you use the "help" ones, be sure to get an extra box, to carry in the glove box. the life span of some of them, can be measured in wipes, not years. * Dodge part # is 3799089 it lists for $5.70
[Re: sthemi]
#1366327
01/11/13 12:03 AM
01/11/13 12:03 AM
Mud Pig
Channel locks, PB blaster? What in the good lord and where would I get those?
[Re: Mud Pig]
#1366328
01/11/13 12:53 AM
01/11/13 12:53 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Most people have them in their toolbox. In your case you may need to take a trip to a place called a hardware store, parts house, or possibly a repair shop that knows what they are doing..
I am truckless..
[Re: Mud Pig]
#1366334
01/14/13 12:49 AM
01/14/13 12:49 AM
Posts: 3,877 Oregon
hooziewhatsit
if you hold the wipers off the windshield do they still shudder?
[Re: Mud Pig]
#1366335
01/14/13 01:16 AM
01/14/13 01:16 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
It was raining so the windshield was definitely wet. As for the pry bar, the bushing wouldn't go on and there wasn't enough space to get plyers in there. Nothing was bent, the linkage arms are right where they should be.
I think the wiper arms are just a little offset from each other which is causing some dragging and shuddering on the windshield. I'll play with them and see if I can get them to run smooth.
Alt easier to pull the assembly out to install bashing in my opinion. They wipers being off from each other shouldn't matter other than going over to far or catching on each other
[Re: 76dodgeboy]
#1366337
01/14/13 09:51 AM
01/14/13 09:51 AM
Mud Pig
You make a good point. I'll check over te blade on the one that's shuddering and see if its damaged at all. I'll make sure to run each one separately by removing the other arm to zero in on the problem. You have to love a classic truck. How does simply replacing to wiper blades turn into hours of work, cut up hands, and a 200 pound pissed off man.
[Re: 340SHORTY]
#1366339
01/15/13 11:05 AM
01/15/13 11:05 AM
Mud Pig
:Murphy's Law""
The shuddering is most likely a worn blade or something on the window. Highly unlikely it has anything to do with the linkage unless a transmission is bad.
Well, here's the rub. After calmly looking at everything, linkages, wiper arms, blades, all of a sudden it dawned on me that the wiper arms were on backwards. The left one was on the right, and the right one was on the left. Turns out that the last person to touch them put them on backwards. I know I didn't do it, given that I laid the arms on the side of the truck they came off of.
So that helped the shudder out, but unfortunately its still there. Going to get some rain X and do a throrough cleaning of everything tonight. Hoepfully, that will solve it once in for all.
The wipers are getting on my last nerve.
[Re: 76dodgeboy]
#1366341
01/15/13 02:15 PM
01/15/13 02:15 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
A shudder is almost always blade or arm related, either the blades are shot, the arms are twisted, or the connection between the blades and the arms is too loose. Put new wiper blades on the truck, its the cheapest place to start and the most likely problem. They tend to "lay over" after they have been against a windshield for a while. When the wipers are running, the blades shift from side to side as they go across the windshield. Old, laid over, blades don't shift over very well, and tend to shudder. Also check to be sure the blades are not sloppy loose at the pivot points where the blades attach to the arms, as that will also cause a shudder. Gene
[Re: poorboy]
#1366342
01/15/13 04:08 PM
01/15/13 04:08 PM
Mud Pig
They are new blades as of a two weeks ago. But the number of times I've had to pull the arms off the car they may have been damaged. Its one of those things that really isn't the biggest deal, but I'm on a mission now. To quote GW, "This agression will not stand!!". These wipers are going to answer to me one way or another.
[Re: Mud Pig]
#1366343
01/31/13 06:37 PM
01/31/13 06:37 PM
Posts: 85 Rio Linda, CA
nytemuvr
Rio Linda, CA
If you clean the winsheild with a wet sponge with Bon Ami, it takes off the build up off the windsheild and your wiper won't shutter so much. Don't use Ajax or Comet as they will scratch the glass. Bon Ami is the same powder(cerilium powder?) that glass shops use to polish windows with. I've done that each year before the rain starts when I put on new wiper blades. May not solve the problem completely but will help alot, especially if you RainX them after cleaning them with Bon Ami(any grocery store should have it).Just did it 3 or 4 months ago and my wipers work much better on my D100 and Challenger.
1972 Challenger 340(original owner)
1968 D100
1997 HD Road King
