First Paint Job - Need Tools! #1365587
01/06/13 11:04 PM
01/06/13 11:04 PM
San Antonio, Tx
bulletpruf Offline OP
San Antonio, Tx
Fellas -
Plan to paint my 68 Lemans convt and believe that's an excuse to purchase some new tools. Car is in pretty good shape, but needs some dents worked out, minor rust repair. Think I'm going to do a "scuff and shoot" over the existing paint.
Anyway, in addition to the normal hand tools, I have a DA orbital sander, DeVilbiss HVLP "Finish Line" gun (1.3, 1.5, 1.8 tips), 80 gallon compressor, MIG welder (Miller 211), cutoff wheel, sheetmetal nibbler, die grinder, etc.
Figure I need:
Hammers and dollies - what about this set from Eastwood - http://www.eastwood.com/7-pc-body-and-fender-pro-set-fiberglass-handles.html
Also need some sanding blocks, right? How 'bout these - http://www.eastwood.com/7-pc-body-and-fender-pro-set-fiberglass-handles.html
What about an air sander? http://www.eastwood.com/straight-line-air-sander.html
And a palm sander?
I have a pair of the metal stands that can be used to support bumpers, fenders, decklids, doors, etc while you are working on them.
Suppose I'll need a pile of sandpaper as well as masking tape and paper.
What did I miss? Recommendations on the above list?
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365588
01/07/13 08:18 AM
01/07/13 08:18 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The air sander you linked to has only 1 customer review on Eastwood's site, and it is not good. Just an FYI, consider this a
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365589
01/07/13 08:40 AM
01/07/13 08:40 AM
Millersville, PA
HemiChallenger Offline
Millersville, PA
Consider picking up a shrinking hammer and slapper bar as well. If you have an area with larger issues a slapper bar will come in handy. Get a 6" random oribital sander, and Durablock kits have a good variety of blocks...
Steve
Re: First Paint Job - Need Tools! [Re: HemiChallenger] #1365590
01/07/13 11:48 AM
01/07/13 11:48 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do yourself a favor and get a WATERBUG.
Re: First Paint Job - Need Tools! [Re: GO_Fish] #1365591
01/07/13 12:31 PM
01/07/13 12:31 PM
San Antonio, Tx
San Antonio, Tx
I saw that. Is the air sander a good piece of gear? If it saves time, makes the job easier, etc, I'm all about getting it. One thing that I've learned as I have gotten older - - having the right tools can make a huge difference in my productivity.
Re: First Paint Job - Need Tools! [Re: HemiChallenger] #1365592
01/07/13 12:31 PM
01/07/13 12:31 PM
San Antonio, Tx
San Antonio, Tx
Steve
Thanks, Steve. That's helpful.
Scott
Re: First Paint Job - Need Tools! [Re: bonefish] #1365593
01/07/13 12:32 PM
01/07/13 12:32 PM
San Antonio, Tx
San Antonio, Tx
That's a new one for me - - what is it?
Scott
Re: First Paint Job - Need Tools! [Re: bonefish] #1365594
01/07/13 12:36 PM
01/07/13 12:36 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
It sounds like you want the go-ahead to tool splurge!
You can usually get a toe dolly, combo dolly, picking hammer, shrinking hammer and a slapper used. Tools are nice, but you will want the money ON the car, not in your box.
I try to find a fender or hood from the same era for metal, rather than buy a flat sheet of modern metal.
The thing that stands out for me on the list is the compressor. Check your CFM rating on the gun and the compressor. It may not be able to keep up.
Don't forget personal safety stuff! Don't shoot without a good mask at least. Good to have something for when you are sanding too.
Talk to your local paint supply place and they should set you up with materials that work well together and are easy for a newbie. If possible, drive it over and have them look it over before you start. Use real tape, not the Home Depot stuff. Same with the paper or plastic masking. No newspaper!
Also, start lubing any fasteners that will be removed. Once the thing is bare, you do not want ANY spray stuff around, especially anything with silicone (armor all, tire dressing) - it's asking for fish eyes!
If possible, use a local college facility. It works for me!
EDIT: One tool that I've used a lot is a stud gun.
You can even use it to shrink a oil canned dent.
Here's a cheap one.
http://www.toolsource.com/magnaspot-1000...urceid=googleps
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365595
01/07/13 01:32 PM
01/07/13 01:32 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Scott
i dont know how to cut and paste,just google waterbug sander.i love mine.
Re: First Paint Job - Need Tools! [Re: RodStRace] #1365596
01/07/13 10:58 PM
01/07/13 10:58 PM
San Antonio, Tx
San Antonio, Tx
Here's a cheap one.
Great input. Thanks!
Scott
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365597
01/09/13 01:58 PM
01/09/13 01:58 PM
San Antonio, Tx
San Antonio, Tx
Fellas -
Got the Martin 7 piece hammer and dolly kit with fiberglass handles. $196 at Summit or $226 at autobodytoolmart.com - http://www.autobodytoolmart.com/martin-7-piece-hammer-dolly-set-p-13681.aspx
I went with the Dura-Block 7 piece kit for $60 - http://www.summitracing.com/parts/ard-tai-af44l/overview/
Added a 24" Dura-Block for $28 - http://www.autobodytoolmart.com/dura-block-24-x-2-34-sanding-block-p-12944.aspx
Also got the Martin book on metal bumping for $12.
I'll also pick up some 3M tape and masking paper. Any particular style/type to get?
What about sandpaper? Looks like I can get rolls of 3M "stikit" stuff, but it's not cheap at $45/roll. What flavors/grits will I need? http://www.autobodytoolmart.com/3m-stikit-gold-sheet-2-34-sandpaper-rolls-p-11340.aspx
I have a regulator and water trap on my compressor now (80 gallon Quincy 230 volt), but do I have to spend $500 on a new dryer and filter? http://www.autobodytoolmart.com/devilbis...us-p-15078.aspx
Or can I use a Harbor Freight one for $50? http://www.harborfreight.com/38-desiccant-dryer-with-oil-removal-filter-69923.html
I have to replace my hose for this job, right? Think I saw somewhere that I shouldn't use my old air hose for painting.
Stud gun looks like a good piece of gear, but I don't have any large dents on this car that I'm aware of. Just some small dings in the trunk and tops of the fenders and quarters from some hail. Do you use a stud gun on small dents like this?
Thanks,
Scott
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365598
01/09/13 05:17 PM
01/09/13 05:17 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
If you can get to the back of every dent, don't bother with a stud gun.
The sanding blocks will determine the sandpaper. Always use good quality paper (3M) not cheap stuff.
There are a ton of how-to videos on you tube and available for purchase.
For the air, there are a lot of clever ways to filter the air and get the moisture out. For one job, there is NO WAY I'd spend 500 bucks on equipment.
I posted about the hoses and fittings. It has info in the links.
I'd suggest shooting primer on smaller stuff first, to test the limits of your system.
If you can work up to two fenders and a hood without a pressure or volume drop, you should be able to do a body...
Re: First Paint Job - Need Tools! [Re: RodStRace] #1365599
01/09/13 08:58 PM
01/09/13 08:58 PM
San Antonio, Tx
San Antonio, Tx
I can't get to the back of all the dents; some in the decklid will be behind the decklid inner structure/frame.
I didn't see the links you referenced above.
Not at home so I don't have the gun model, but looks like the gun will need 10-13 cfm. Compressor is rated for 17 cfm, I believe.
Thanks,
Scott
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365600
01/10/13 12:40 AM
01/10/13 12:40 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
links posted here
https://board.moparts.org/ubbthreads/show...rue#Post7538313
Found this group of body videos, Haven't watched them yet, so I can't vouch for them. There are lots of others.
http://www.youtube.com/user/ButlerCollision?feature=watch
Re: First Paint Job - Need Tools! [Re: RodStRace] #1365601
01/10/13 02:24 PM
01/10/13 02:24 PM
San Antonio, Tx
San Antonio, Tx
links posted here
Thanks for the info.
Scott
Re: First Paint Job - Need Tools! [Re: bulletpruf] #1365602
01/10/13 03:03 PM
01/10/13 03:03 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Did anyone answer ...What is a water bug and where can I get one ??
Re: First Paint Job - Need Tools! [Re: dynamite] #1365603
01/10/13 03:49 PM
01/10/13 03:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Google is your friend.
http://www.google.com/search?q=water+bug...mp;sourceid=ie7
