Page 1 of 3 1 2 3
440 source stroker kit/balancing quality #1365525
01/06/13 10:39 PM
01/06/13 10:39 PM
RapidRobert Offline OP
A good friend wants to purchase a stroker kit from them. Their site says the quality/meticulousness they incorporate is second to none. I want to have it checked out by a local machinist who is also a perfectionist but that of course will be extra $$$ that he will have to expend. What do YOU guys suggest. Thank you for your time.
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365526
01/06/13 10:54 PM
01/06/13 10:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Doesn't matter whose stroker kit you purchase, it should be gone thru to confirm all specs/fit/finish, it's foolish to pass off any engine component with out checking it out, regardless of the "name" on it....
Re: 440 source stroker kit/balancing quality [Re: DAYCLONA] #1365527
01/06/13 10:57 PM
01/06/13 10:57 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
By most accounts they are pretty close OOTB. But it never hurts to double check...
Re: 440 source stroker kit/balancing quality [Re: bobs66440] #1365528
01/06/13 11:19 PM
01/06/13 11:19 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
So far no kit I've used from Source has been ready to run. Admittedly I haven't used one in a couple years. But the cranks are usually within factory tolerances for taper and clearances. But they have taper and the clearances will vary journal to journal. The rods - they will need the big ends re-sized once the bolts are cycled with the right lubricant (the factory does not use the ARP lube so they are not torqued properly when finish machined). The pin ends will need honed and against the advice of the manifacturer - sand paper is not the way to do it. In terms of balancing - the rods in total are weight matched. However, when it's balanced the ends are weighed seperately - and every set has needed the rods worked to get them truly weight matched. The best part of the kits are the pistons. Which are pretty good over all.
Re: 440 source stroker kit/balancing quality [Re: DAYCLONA] #1365529
01/06/13 11:21 PM
01/06/13 11:21 PM
PA
noplanb Offline
noplanb  Offline
PA
x1000
remember when you said honey, some day that car is gonna look so good in front of our house
Re: 440 source stroker kit/balancing quality [Re: noplanb] #1365530
01/06/13 11:47 PM
01/06/13 11:47 PM
Alright I will insist that he go the extra $$$ & have it checked out especially since I will be responsible for the final assembly/breakin/tune up/how it performs/longevity. Thanks guys
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365531
01/06/13 11:56 PM
01/06/13 11:56 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
i can't say about the 440- source stuff. i will say i would check any ordered part for proper fit and or clearances. i personaly have used callies cranks,rods and a mhale piston/ring sets. always with great results both fit and durability...mabe more $ but you get what you pay for .
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365532
01/07/13 12:21 AM
01/07/13 12:21 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Then I would definitely insist he ponys up the $ to have it checked by a pro. How would you feel if it flew apart, ate a bearing or whatever and your buddy looks at you...
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365533
01/07/13 12:33 AM
01/07/13 12:33 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I personally wouldn't spend extra for a balanced assembly because it's just one more thing you will have to have checked and possibly corrected by your machinist. By the time you pay to check it you might as well put some more with it to have it all done and know it's right. JMHO
Kevin
Re: 440 source stroker kit/balancing quality [Re: DaytonaTurbo] #1365534
01/07/13 12:43 AM
01/07/13 12:43 AM
He'd do more than look at me plus I'd have to refund what I'm gonna charge him for assembly and there'd be no future work & my rep around town would suffer & I would feel extremely bad & that's why I'm insisting that a local machinist check everything. Yeah I believe half of what I see and none of what I hear but he was taken by their glowing verbiage on their site & we've went around & around on this for several weeks finally I said I'll check in with the guys for a second opinion. Now that I have it I'll for sure insist that it go to one of the 2 local shops
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365535
01/07/13 01:08 AM
01/07/13 01:08 AM
Manitoba, Canada
Manitoba, Canada
IIRC, 440source specifically states you need to check the pin clearance on their rods, so that's something to keep in mind. And I've heard stories of eagle, scat, etc parts needing corrections as well. Best to assume nothing. Just hope the machinist does his job!
Re: 440 source stroker kit/balancing quality [Re: DaytonaTurbo] #1365536
01/07/13 01:25 AM
01/07/13 01:25 AM
Yes he's extremely meticulous, the only caveat with him is I just have to be sitting down when I open up his bill
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365537
01/07/13 01:40 AM
01/07/13 01:40 AM
Vancouver, WA
Cuda Cody Offline
Cuda Cody  Offline
Vancouver, WA
I was happy with their product and the quality.
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365538
01/07/13 03:41 AM
01/07/13 03:41 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When I measured my 4.25" stroker kit, The weights were very close to what I measured with a bobweight difference of less than 1 gram. I also checked the rod big ends with a bore gauge for roundness and taper when torqued with ARP Ultra lube, and they checked out fine. These were the older "I" beam rods, with the ARP2000 bolts, so I don't know if the "H" beam rods may be different?
I would not say the kits are perfect, and the bearing clearances are a bit tight for a race engine (around 0.002"), but are fine for a street engine.
I have my 4.15 stroker apart and the machine shop had this "balanced", but I am going to have it re-checked because the engine was not real smooth, and I will deepen the valve pockets on the pistons. I am curious if the machine shop may have made the balance worse?
Re: 440 source stroker kit/balancing quality [Re: 451Mopar] #1365539
01/07/13 09:25 AM
01/07/13 09:25 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
having the parts checked out is always a good idea no matter who you use.
I have a 440 source kit and it runs great. 535 tq/505 hp in a 383 block, it had 4500 street miles before I pulled it out of the truck, and now it's sitting awaiting for a refreshen and to be placed in the cuda when the time comes.
**Photobucket sucks**
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365540
01/07/13 10:51 AM
01/07/13 10:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tell him to save his money and just have the local guy balance it and not pay the source for it ????
oh wait , let me guess , you can only buy their kits balanced ...
Re: 440 source stroker kit/balancing quality [Re: JohnRR] #1365541
01/07/13 11:29 AM
01/07/13 11:29 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I just purchased an Eagle stroker kit, machine shop had to rebalance the entire assy, and the oil seal journal wasn't even close,...so it dosen't matter who/what name is on the work/box, it pays to have it checked...
Mike
Re: 440 source stroker kit/balancing quality [Re: DAYCLONA] #1365542
01/07/13 11:46 AM
01/07/13 11:46 AM
I'm convinced & I needed some backup on this. You know how customers are about spending money twice & this guy is a friend. Thanks again guys
Re: 440 source stroker kit/balancing quality [Re: RapidRobert] #1365543
01/07/13 12:46 PM
01/07/13 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He may be a friend but don't short change yourself, if something goes wrong with the engine who is going to be the warranty station, if its you are you getting enough to be the warranty station ?
I stopped doing stuff like that for friends because I'm not getting paid enough to have to pay out of my pocket to redo something I have no control over how it is being treated.
Plus when it comes to money you'll see how good a friend the person really is ...
Re: 440 source stroker kit/balancing quality [Re: JohnRR] #1365544
01/07/13 01:16 PM
01/07/13 01:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Amen Brother...
Page 1 of 3 1 2 3
