Page 1 of 3 1 2 3
new best for the "land yacht" #1365474
01/06/13 10:26 PM
01/06/13 10:26 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ran a 10.50 @ 120.77 at Speedworld on Saturday. Yes, only 120. 1.44 60 foot. Lost 2 plugs in high gear when the ground straps melted off. Damage accessment to follow.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365475
01/06/13 10:31 PM
01/06/13 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good and bad story............I assume you squeeze this thing?
Re: new best for the "land yacht" [Re: Thumperdart] #1365476
01/06/13 11:16 PM
01/06/13 11:16 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Yep.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365477
01/06/13 11:18 PM
01/06/13 11:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Hopefully you got lucky. My 340 always got a piston or a head gasket. Since I reduced my timing (1991) to 30 total it 's never hurt itself again at12lbs boost.
Doug
Re: new best for the "land yacht" [Re: Crizila] #1365478
01/06/13 11:22 PM
01/06/13 11:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep.
Oh, THAT kind of squeeze..............hope there`s not much damage for you.
Re: new best for the "land yacht" [Re: Thumperdart] #1365479
01/06/13 11:46 PM
01/06/13 11:46 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Hope it's not too bad John.
Re: new best for the "land yacht" [Re: dvw] #1365480
01/07/13 02:00 PM
01/07/13 02:00 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Doug
Same timing I was running. Unfortunately, a little more boost - 25 psi.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365481
01/07/13 02:27 PM
01/07/13 02:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Doug
This is one of the reasons I run N/A. I can barely tune my heap let alone nos or blower stuff......... When you gonna tear into it?
Re: new best for the "land yacht" [Re: Thumperdart] #1365482
01/07/13 02:58 PM
01/07/13 02:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Congrats on the new best. Hope you did not hurt it to bad. Ron
Re: new best for the "land yacht" [Re: Thumperdart] #1365483
01/07/13 03:08 PM
01/07/13 03:08 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Doug
Probably tomorrow. I had no business running that amount of boost. Stupid me!! Ran with the wrong size pulley on the blower for the rest of the set up. All I needed to do was run the larger blower pulley with the CORRECT belt tension. One thing about drag racing - when you do stupid stuff, you always pay.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365484
01/07/13 03:25 PM
01/07/13 03:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd do a compression check. If its good then go a range colder on the plugs, back the timing back five to seven degrees and depending on A/F fattin it up a couple jets and try again. Once its dialed in for hi boost it's time to play!
Re: new best for the "land yacht" [Re: FastmOp] #1365485
01/07/13 07:11 PM
01/07/13 07:11 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Ya,all the above. Just ran a comp test and all appears good (within 2 lbs from previous test on all holes ). Valve train all looks good, including lash. Attached pic of plugs - NGK ZFR5F. Two burned ones were in holes 4 & 5. I'm open for suggestions on plugs? Could go a few steps colder - or maybe something that isn't an extended core? Already 5 sizes bigger on the jets all around - as I received the blower carb from ProSystems ( annular discharge 950 ). I could use some help with plug selection ( 408 blower motor with ported Magnums ).
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365486
01/07/13 07:17 PM
01/07/13 07:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Go to the race plugs first off. Start with a plug on the colder side and go from there. Does not look to bad do as fastmop suggests and get after it.
Re: new best for the "land yacht" [Re: Crizila] #1365487
01/07/13 09:12 PM
01/07/13 09:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ah,Lucky. I think 25lbs might work intercooled. Would need less timing, 22-25? The super rich part I'm not convinced. Just as running a nitrous motor,way rich usually spells trouble. I've found 11.8-12.0 to work well. Mine always hurt #5.
Doug
Re: new best for the "land yacht" [Re: Al_Alguire] #1365488
01/07/13 10:01 PM
01/07/13 10:01 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Will look at going with some race plugs and maybe cutting the timing back a few degrees ( 30 to 28 ). Maybe go up a nozzle size on the water injection. Think I will also go back to a 4" blower pulley ( was running a 3.7" ) until I can get a clean run out of it.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365489
01/07/13 11:17 PM
01/07/13 11:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Do you know the A/F of that run before it got hot?
Get some vids on YouTube. It's winter and were bored
Re: new best for the "land yacht" [Re: Crizila] #1365490
01/07/13 11:24 PM
01/07/13 11:24 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Glad you didn't hurt it. I was doing some dyno testing, and mine wasn't happy beyond 21° of timing at 18 psi of boost. I'm running 9.5:1 compression.
Oh, and GREAT TIME TOO!!!
Re: new best for the "land yacht" [Re: Duner] #1365491
01/07/13 11:37 PM
01/07/13 11:37 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Put the biggest nozzle in the meth inj. Run a ngk 5671-9 or 10 and let her rip. 11.8-12.0 is a good afr to shoot for on a blower motor.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: new best for the "land yacht" [Re: 1967dartgt] #1365492
01/08/13 12:34 AM
01/08/13 12:34 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for the plug recommendations. Can't keep it lit with the biggest nozzle, but I will go to the middle size. I don't monitor A/F, but looking in to a wide band unit. Thanks Duner. I do have a video of the run as I was monitoring the boost and tach gauges. Rev limiter was set at 7K and I was up against it several times. Surprised it went 10.50 as I was in and out of the throttle at the end of the run. I'll try and post it.
Fastest 300
Re: new best for the "land yacht" [Re: Crizila] #1365493
01/08/13 02:09 AM
01/08/13 02:09 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
I've read alot of bad things about running meth if you don't have almost perfect distribution across all the intake runners...don't know this from experience though. As for the wideband, I've got a LM-2 Innovate and I love it. It kept me from pulling my hair out trying to get a good safe tune. I run 93 pump (E10) on the street and 100LL avgas when I want to set it on kill. I've been as high as 18lbs with cast pistons and avgas, would have never felt safe doing it without a wideband
Page 1 of 3 1 2 3
