318 motor noise #1365339
01/06/13 07:52 PM
01/06/13 07:52 PM
bunerhill il
speedfreak Offline OP
bunerhill il
i just bought a 90 d150 318 auto the truck has 110 000 on it.it has a internal motor noise it doesnt sound consistant. i pulled valve covers all looks tight it sounds valvetrain? is there any advice before i dig in to deep
Re: 318 motor noise [Re: speedfreak] #1365340
01/06/13 07:58 PM
01/06/13 07:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A little more info on this noise might help narrow it down.
Don't be the exception.
Re: 318 motor noise [Re: Supercuda] #1365341
01/06/13 08:08 PM
01/06/13 08:08 PM
bunerhill il
bunerhill il
when it idles it sonds like a bent pushrod or calapsed lifter when you bring up the rpms it gets louder and kind of sparatic it doesnt sound like a rod or low end at least from my exp.thanks
Re: 318 motor noise [Re: speedfreak] #1365342
01/06/13 08:14 PM
01/06/13 08:14 PM
STL
cdstl Offline
cdstl  Offline
STL
Bob,
Your not set up to accept Private Messages. Are you in Bunker Hill?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 318 motor noise [Re: cdstl] #1365343
01/06/13 08:25 PM
01/06/13 08:25 PM
bunerhill il
bunerhill il
yes i am as for as the private message idont know my way around this thing yet?
Re: 318 motor noise [Re: speedfreak] #1365344
01/06/13 09:05 PM
01/06/13 09:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
my guess is a collapsed lifter
Re: 318 motor noise [Re: speedfreak] #1365345
01/06/13 09:26 PM
01/06/13 09:26 PM
STL
cdstl Offline
cdstl  Offline
STL
yes i am as for as the private message idont know my way around this thing yet? [/quote
At the top of the page go to My Home. Then look for Personal information, email, password, etc. At the far right is edit. Click on it and at the bottom of the next page you can allow PMs. When you get a PM there will be a small letter icon flashing at the top where it says Welcome speedfreak
I'm in Edwardsville.
Re: 318 motor noise [Re: mopars4ever] #1365346
01/06/13 10:40 PM
01/06/13 10:40 PM
bunerhill il
bunerhill il
a lifter is the way i am leaning appreciate your input
Re: 318 motor noise [Re: speedfreak] #1365347
01/06/13 10:58 PM
01/06/13 10:58 PM
press straight down on the rocker arms (pushrod end) with it idling with the end of a hammer with a wooden handle & this will alter/somewhat quiet a bad lifter to help you id a bad one
Re: 318 motor noise [Re: RapidRobert] #1365348
01/06/13 11:50 PM
01/06/13 11:50 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Loose torque converter bolts?
Re: 318 motor noise [Re: bobs66440] #1365349
01/07/13 02:43 AM
01/07/13 02:43 AM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
had that once... do what rapid said as well as the TC bolts..
