How Do You Know When Clutch-type Suregrip Needs Rebuilt #1365165
01/06/13 02:50 PM
01/06/13 02:50 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Right now with my clutch-type sure grip, my driver's side quarter panel is showing way more chunks of rubber from burnouts than my passenger side quarter panel. Also, the slick on the driver's side shows more wear.
Other than that, the car launches just fine, nice and straight. It stays straight in the burnout box too. Any ideas? Thanks!
Re: How Do You Know When Clutch-type Suregrip Needs Rebuilt [Re: 67Satty] #1365166
01/06/13 04:13 PM
01/06/13 04:13 PM
What your seeing is normal, the driveshaft rotation trys to push the drivers side tire into the ground and at the same time trys to lift the passneger side tire up making it spin easier, as long as the car gies stright your golden Are your slicks directional, arrows showing which way the tires should rotate? If not rotate them from side to side about every ten to twenty runs You might want to consider doing shorter burn outs also
Re: How Do You Know When Clutch-type Suregrip Needs Rebuilt [Re: Cab_Burge] #1365167
01/06/13 05:06 PM
01/06/13 05:06 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Thanks, I'm due for a rotation then. And yeah, I've been trying not to get too carried away with the burnouts.
Re: How Do You Know When Clutch-type Suregrip Needs Rebuilt [Re: 67Satty] #1365168
01/06/13 06:36 PM
01/06/13 06:36 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
spool time?
Re: How Do You Know When Clutch-type Suregrip Needs Rebuilt [Re: Cab_Burge] #1365169
01/06/13 07:15 PM
01/06/13 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The drive shaft says its trying to rotate the load
to the drivers side tire.... the body rolls to the
RR... thats why we pre load the pass side tire...
the more torque the engine makes the more we pre load
that side...... BUT if its driving out STRAIGHT...
leave it alone
