trans brake #1364850
01/05/13 08:00 PM
01/05/13 08:00 PM
florida dade
cesar perez Offline OP
florida dade
i have a 572 ci dart with roller cam -5500 stall converter-410 gears-30x13 inch slicks and 2900 lbs what would you guys recommend as far as what rpm leaving on transbrake?
Re: trans brake [Re: cesar perez] #1364851
01/05/13 09:20 PM
01/05/13 09:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If the suspension will take it I would start at 5000
and work up
Re: trans brake [Re: MR_P_BODY] #1364852
01/05/13 09:33 PM
01/05/13 09:33 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have a 5600 converter, i launch at 4400 rpm. this gave me my best 60's.
Re: trans brake [Re: rebel] #1364853
01/05/13 10:13 PM
01/05/13 10:13 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
My converter stalls 5900 and I set the two step at 3600,,,but I run a smallblock.
Re: trans brake [Re: dartman366] #1364854
01/06/13 02:04 AM
01/06/13 02:04 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
this^^^
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: trans brake [Re: bigtimeauto] #1364855
01/06/13 01:40 PM
01/06/13 01:40 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Converter is 6000 but a 1.80 glide, usually launch at 3600 (most consistant 60' for me).
When I used a 727 and a smaller motor (451) with a 5300 converter I was always between 3000 and 3600, usually 3000.
Re: trans brake [Re: 540dust] #1364856
01/06/13 01:45 PM
01/06/13 01:45 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
34-3600ish
Re: trans brake [Re: cesar perez] #1364857
01/06/13 03:00 PM
01/06/13 03:00 PM
Penna
70satelliteguy Offline
Penna
Cesar I have a 572 with 5000 stall and 4:10's with 31/14.0 slicks and I leave off the brake at 4500. I am at 3600 lbs. though with me in it! Wish I was at your weight!!
Have you run the car yet with the brake or is this a brand new combination?
Can you give more info about motor,et's and 60 fts.?
Mike
Re: trans brake [Re: cesar perez] #1364858
01/06/13 04:21 PM
01/06/13 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I can say for fact that the higher the RPM I leave
at the quicker the 60'... I have a 5600 stall and I
leave at 5600... no chip... that gives me a 1.19 60'
I would like to go to a 6000 conv and start upping
the revs to see if that gives me a better 60'....
its all what your chassis can take... why have your
torque at 5000+ rpm and leave at 3000......JMO
I know alot of guys that the chassis cant do it but
they also dont like doing chassis work and just leave
it alone
Re: trans brake [Re: MR_P_BODY] #1364859
01/06/13 06:44 PM
01/06/13 06:44 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
it alone
I'm the same as Mr.P ...well atleast after I put the anti-roll in. Up until the new BGR mill I always left on the wood with a 5800 stall...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: trans brake [Re: Eric] #1364860
01/06/13 11:40 PM
01/06/13 11:40 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
it alone
Same here. Put a brake in towards the end of the season and started out with the chip at 3000 and kept working up. Was up to 4200 at the end of the season and had the best 60's ever. Converter stalls at 5400 , so I can still try going higher on the 2 step. But it going to have to wait for a few months before I can try it .
