Re: Msd Question
[Re: bobs69]
#1364810
01/05/13 06:49 PM
01/05/13 06:49 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The coil is firing into the dist. nothing comming out of the wires. Anyone know why? Not that it makes any difference but it is all new and was running before
Look to see if the rotor is there.. next make sure the carbon ball is in the center where the rotor touches
Re: Msd Question
[Re: MR_P_BODY]
#1364811
01/05/13 07:40 PM
01/05/13 07:40 PM
Posts: 813 ar.
bobs69
ar.
Re: Msd Question
[Re: bobs69]
#1364812
01/05/13 07:50 PM
01/05/13 07:50 PM
Posts: 3,695 nc
emarine01
nc
Re: Msd Question
[Re: rickraw]
#1364815
01/05/13 08:34 PM
01/05/13 08:34 PM
Posts: 2,177 ill
dennismopar73
ill
lets see,, we have fire and it is going to the cap ! ,, check,, we have no fire going out to the plug wires !, check, mmm bad rotor ,, bug cracked... broke,,, burned,or the rotor is not turning! it is either an easy fix , or something has broke on the dist shaft!
Re: Msd Question
[Re: emarine01]
#1364819
01/05/13 09:40 PM
01/05/13 09:40 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I had a bent oil pump shaft once and it would cause trouble. The rotor was turning and crashing into the terminals and tearing off the tip.
Re: Msd Question
[Re: Dartwizer]
#1364825
01/06/13 06:53 PM
01/06/13 06:53 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I had a problem like that as well. The gap on the electronic pick up module in the dist had spread way to far from the reluctor to tell it when to spark
Re: Msd Question
[Re: HOTMOPR]
#1364826
01/06/13 07:02 PM
01/06/13 07:02 PM
HOTMOPR
Oakville, Wa
Guess I should have read it better since you have spark to the cap..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Msd Question
[Re: HOTMOPR]
#1364827
01/06/13 07:05 PM
01/06/13 07:05 PM
MR_P_BODY
If its firing from the coil its firing.... now was it a weak spark (not a pick up issue) thats a coil issue but as said was it getting THROUGH the coil tower on the cap.... a stronger coil WILL jump more resistance
Re: Msd Question
[Re: bobs69]
#1364828
01/06/13 08:43 PM
01/06/13 08:43 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
might want to check to make sure you have the + and - correct that go to the coil from the box.
Joe
Without Data, you’re just another guy with an opinion.
