Msd Question #1364809
01/05/13 06:40 PM
01/05/13 06:40 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
The coil is firing into the dist. nothing comming out of the wires. Anyone know why? Not that it makes any difference but it is all new and was running before
Re: Msd Question [Re: bobs69] #1364810
01/05/13 06:49 PM
01/05/13 06:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Look to see if the rotor is there.. next make sure
the carbon ball is in the center where the rotor touches
Re: Msd Question [Re: MR_P_BODY] #1364811
01/05/13 07:40 PM
01/05/13 07:40 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
YeS and Yes
Re: Msd Question [Re: bobs69] #1364812
01/05/13 07:50 PM
01/05/13 07:50 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
What type cap?
Re: Msd Question [Re: emarine01] #1364813
01/05/13 08:04 PM
01/05/13 08:04 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
hei cap This is the second time this has happened. First time we borrowed a friends cap wires and rotor put them on and it fired up. So we bought new cap rotor and wires put them on it fired up was idling fine then it shut down like you turned the key off. Has not fired thru the plug wires since then.
Re: Msd Question [Re: bobs69] #1364814
01/05/13 08:09 PM
01/05/13 08:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd start checkin the wiring. possible open, or bad ground somewhere.
Re: Msd Question [Re: rickraw] #1364815
01/05/13 08:34 PM
01/05/13 08:34 PM
ill
dennismopar73 Offline
ill
lets see,, we have fire and it is going to the cap ! ,, check,,
we have no fire going out to the plug wires !, check,
mmm bad rotor ,, bug cracked... broke,,, burned,or the rotor is not turning!
it is either an easy fix , or something has broke on the dist shaft!
Re: Msd Question [Re: rickraw] #1364816
01/05/13 08:35 PM
01/05/13 08:35 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
This is a new build. We re did all the ground wires it has a motor plate we changed the msd box added ground straps ran the ground back to the battery. Nothing changes it. We are going to call msd monday see if they can help
Re: Msd Question [Re: bobs69] #1364817
01/05/13 08:40 PM
01/05/13 08:40 PM
ill
ill
If the msd has fire, and you say it is firng to the cap then the MSD will be good it has to be a bug/cap ordeal,
I had my cap and bug burn up on my chevy truck where the coil wire goes into it would fire to the cap nothing to the plugs cost me missing a visitation and 250 tow bill
Re: Msd Question [Re: dennismopar73] #1364818
01/05/13 09:36 PM
01/05/13 09:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
It could be a rotor phasing problem, Its firing in the center of the 2 plug terms on the cap?
Re: Msd Question [Re: emarine01] #1364819
01/05/13 09:40 PM
01/05/13 09:40 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I had a bent oil pump shaft once and it would cause trouble. The rotor was turning and crashing into the terminals and tearing off the tip.
Re: Msd Question [Re: Leon441] #1364820
01/05/13 09:58 PM
01/05/13 09:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
How good of a spark ? should be real nasty/strong . out of the coil wire.. make you want to weld with it. blue in color..
Re: Msd Question [Re: Leon441] #1364821
01/05/13 10:03 PM
01/05/13 10:03 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
I had a simular deal with my MSD system on my Dart a while back.I have a billet dist ,6Al ,and a blaster 2 coil.It would start and run fine for a few minutes ,then it would begin to break up and then die,then wouldnt start back for awhile .It would then start and do it all over.After changing the coil ,cleaning my grounds and calling the MSD tech support , i could only figure the box was bad.When i would jumper wire the dist the box would churp like it should and fire ,then it wouldnt.I finally found the problem as i was taking the box off the car.It had a loose terminal on the hot side where it went to my starter.I ran it to the starter when i moved the battery to the trunk.The wire was making contact then it wouldnt.Thats box needs 12 full volts at all times...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Msd Question [Re: VernMotor] #1364822
01/05/13 10:13 PM
01/05/13 10:13 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
..and make a humming/buzzing/squeal type noise.
If you like drag racing, support your local track.
Re: Msd Question [Re: CHAPPER] #1364823
01/05/13 11:02 PM
01/05/13 11:02 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Well we changed the coil and it's running again hopefully that will fix it. Thanks
Re: Msd Question [Re: bobs69] #1364824
01/06/13 02:18 AM
01/06/13 02:18 AM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
Change the cap also,,Had the same thing happen.Found the carbon ball had no fire coming through it. No continuity.Sounds crazy but it fixed my problem!
Re: Msd Question [Re: Dartwizer] #1364825
01/06/13 06:53 PM
01/06/13 06:53 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I had a problem like that as well. The gap on the electronic pick up module in the dist had spread way to far from the reluctor to tell it when to spark
Re: Msd Question [Re: HOTMOPR] #1364826
01/06/13 07:02 PM
01/06/13 07:02 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Guess I should have read it better since you have spark to the cap..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Msd Question [Re: HOTMOPR] #1364827
01/06/13 07:05 PM
01/06/13 07:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its firing from the coil its firing.... now was it
a weak spark (not a pick up issue) thats a coil issue
but as said was it getting THROUGH the coil tower
on the cap.... a stronger coil WILL jump more resistance
Re: Msd Question [Re: bobs69] #1364828
01/06/13 08:43 PM
01/06/13 08:43 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
might want to check to make sure you have the + and - correct that go to the coil from the box.
Joe
Without Data, you’re just another guy with an opinion.
