71 Demon coat hook removal? #1364661
01/05/13 01:36 PM
01/05/13 01:36 PM
NE Iowa
Road_RunnerSteve Offline OP
NE Iowa
Probably a dumb question - how do you remove the interior coat hooks from a 71 Demon???
Re: 71 Demon coat hook removal? [Re: Road_RunnerSteve] #1364662
01/05/13 01:41 PM
01/05/13 01:41 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
It's two pieces. Slide the rubber coat hook up and off. Then there will be a white plastic piece that is screwed onto the roof with a Phillips head screw.
Re: 71 Demon coat hook removal? [Re: pinkduster] #1364663
01/05/13 01:44 PM
01/05/13 01:44 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Re: 71 Demon coat hook removal? [Re: NV69B7RR] #1364664
01/05/13 02:35 PM
01/05/13 02:35 PM
NE Iowa
NE Iowa
Thanks!
Re: 71 Demon coat hook removal? [Re: Road_RunnerSteve] #1364665
01/05/13 03:11 PM
01/05/13 03:11 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Finding that hole again is tough, so if you can leave mark below it somewhere that is later covered up.
