Re: how much hp & tq from my combo
[Re: DaytonaTurbo]
#1364616
01/05/13 03:45 PM
01/05/13 03:45 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Good solid combo, would make right at 500 with some good 270+ cfm flowing heads and a bigger carb. A good 3400 stall 9.5" or 10" vert would be just about right. Invest in a set of Eddies (about as cheap as very good porting anymore) and there's maybe 60-70 hp for the taking.
Had that cam in a 451 stroker with self ported big valve 452's. my Duster ran high 6's in the 1/8th and a 3800 stall Fairbanks (remember those?) vert. That cam is easily a match for the old MP 509 with broader torque and higher RPM potential. Like I said, give it enough Head flow to work with and It'll pull really hard.
[Re: Streetwize]
#1364617
01/05/13 04:00 PM
01/05/13 04:00 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
i would say 377 hp @ flywheel
[Re: BSB67]
#1364619
01/06/13 02:01 AM
01/06/13 02:01 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I would agree that it can make between 425 and 450 depending on the tune. Good luck , Ron
[Re: Streetwize]
#1364620
01/06/13 02:36 PM
01/06/13 02:36 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Got one in the car right now.
