Docol R8 #1364415
01/04/13 09:36 PM
01/04/13 09:36 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
Anyone used this in a build?
SFI DOOR CAR SPECS REVISED - Nov. 5, 2012: The SFI Specs for Full Bodied Car Roll Cages have been revised, effective November 5, 2012. The revised versions are designated as SFI Specs 25.1F, 25.2A, 25.3A, 24.4A, and 25.5A and are immediately available from SFI for use by sanctioning bodies and chassis builders. The extent of this revision is that Docol R8 steel tubing is now allowed as an acceptable structural material for roll cage construction. This addition comes after an extensive engineering review by SFI and the pertinent technical committees. The Docol R8 steel tube dimensions (outside diameter and wall thickness) are the same as those required for 4130 steel, therefore it is not necessary to purchase a new copy of the revised SFI Spec document if you already own the previous version.
Re: Docol R8 [Re: TrWaters] #1364416
01/04/13 11:36 PM
01/04/13 11:36 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have never heard of it. I did a search and found a link to Japanese steel plate.
Re: Docol R8 [Re: tubtar] #1364417
01/04/13 11:40 PM
01/04/13 11:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
But wait........there's more !
http://www.elmia.se/de/subcontractor/Pre...or-drag-racing/
Swedish in manufacture , but no real technical data.
Claims of being easier to weld than CM don't tell me a lot.
I wonder if it has to be tigged ?
Re: Docol R8 [Re: tubtar] #1364418
01/05/13 01:24 AM
01/05/13 01:24 AM
I was told last month by a local chassis guy the DOM tubing had a lot stiffer thickness requirement to be certified as DOM steel tubing for regulation requirements than mild steel tubing does I wonder if DOM is considered the same as this is being called?
Re: Docol R8 [Re: Cab_Burge] #1364419
01/05/13 03:50 AM
01/05/13 03:50 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Yes it has to be TIG welded
Yes it welds very nicely
No it is not the same as DOM
Re: Docol R8 [Re: ProStDodge] #1364420
01/05/13 05:42 PM
01/05/13 05:42 PM
Vermont
TrWaters Offline OP
TrWaters  Offline OP
Vermont
