Caltrac installation, the next delay...... #1364376
01/04/13 08:42 PM
01/04/13 08:42 PM
A Red State
SNK-EYZ Online tonguue OP
SNK-EYZ  Online Tonguue OP
A Red State
I working on installing new springs and Caltracs in my 67 Satellite.
Since I bought the Caltracs used from a buddy I'm trying to figure out if I have all the parts.
Small parts like washers always seem to be missing on used parts.
The springs are new Mopar Perf XHD stock replacement.
Doing a web search hasn't shown me much detail.
What I'm trying to figure out is there anything that goes between the front spring hanger and the bellcranks?
Sorry for the size of the pic, it's off the web and not my actual parts.
I installed and tightened the main bolt and it seems tight on the bellcranks.
I'm thinking it would limit the bellcrank twisting easily.
It's my first time ever installing Caltracs and I'm trying to do it right the first time.
This all started when I was test fitting the TTI Exhaust.
I was gonna install the exhaust, the do the spring swap/caltrac install but I figured out the exhaust would get in the way on the spring swap.
Nothing ever goes as planned.
Edit: last reply has explanation of the latest problem/delay.
Re: Caltrac installation question???? [Re: SNK-EYZ] #1364377
01/04/13 10:50 PM
01/04/13 10:50 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Rich-
I tried using washers on Amy's Barracuda to eliminate some of the gap...ending up removing them when I swapped over to 22" front segments. All they did was make squeaking sounds while driving through the subdivision.
We do not have any washers on the '64. (Been running CalTracs on that car for 10-12 years.)
Re: Caltrac installation question???? [Re: Blues_Cuda] #1364378
01/05/13 12:15 AM
01/05/13 12:15 AM
florida,usa
rdakota340 Offline
rdakota340  Offline
florida,usa
On mine caltracs has aluminum washer that goes between spring and the hanger,Now my brothers 65 Belvedere when he ordered his it came with out them and I told him they where missing he said that they do not use them anymore.
Re: Caltrac installation question???? [Re: rdakota340] #1364379
01/05/13 12:31 AM
01/05/13 12:31 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I had initially put aluminum washers on my wife's Barracuda as well.
Re: Caltrac installation question???? [Re: SNK-EYZ] #1364380
01/05/13 12:47 AM
01/05/13 12:47 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
The caltracs shuld come with a large diameter AL bushing to replace the rubber bushing/shell that would have come installed in the XHD spring eye. The smaller diameter AL bushing is longer than the big bushing and goes through aand is actually what tightens up against the fron spring hanger. The 'bell crank' should flop with no binding.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Caltrac installation question???? [Re: oldiron] #1364381
01/05/13 01:11 AM
01/05/13 01:11 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
What he said.... Do you have the large aluminum bushings? They are a key component to the system.
Re: Caltrac installation question???? [Re: StealthWedge67] #1364382
01/05/13 01:27 AM
01/05/13 01:27 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Rich should have the aluminum bushings on hand...I believe I gave him an old set of leafs that had a pair installed. With that said, these were real old CalTracs...probably John's first commercial effort. They were on a '72 Barracuda I bought out of California years ago.
Re: Caltrac installation question???? [Re: Blues_Cuda] #1364383
01/05/13 06:25 AM
01/05/13 06:25 AM
A Red State
A Red State
Thanks for the replies.
Yes, I have the aluminum bushings and the steel inserts that go inside them.
I pressed them out of the springs I got from you Scott.
The original plan was to use those springs, but that changed when I figured out that they only had a 35 inch rear segment (E-Body) and my car uses a 36 inch one (B-Body).
Both sets have a 22 inch front segment.
I called Caltrac to see why the bellcranks seemed to be binding in the spring hangers and if any washers/spacers were required.
No washers are needed.
The front spring hanger center steel sleeve should be at least 3 inches long (the one that goes all the way through the Caltrac bellcranks).
Mine are 3 and 1/16th.
The width of the bellcranks at the outside should be 2.94 inches.
Mine are 3.0 inches.
That seems to be the problem and what's causing the binding in the front hanger.
The next step is to figure out whether it's because of the bushing width or too much paint or powder coating on the bellcranks.
Re: Caltrac installation question???? [Re: SNK-EYZ] #1364384
01/05/13 11:35 AM
01/05/13 11:35 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
It sounds like you should have a total of 1/16" the way it is since the sleeve is 3 1/16. Does it look centered or is it binding on one side or both? Is it the original spring mount? Does that need sanding off rust/grunge? Is the aluminum bushing centered in the spring?
Just some thoughts?
Re: Caltrac installation, the next delay... [Re: oldiron] #1364385
01/12/13 05:05 AM
01/12/13 05:05 AM
A Red State
A Red State
I finally got to pick up the new XHD leaf springs from the dealer today and ran into the next mild delay.
It feels like one step forward and two steps back.
The new Mopar springs use a 1.5 inch diameter front bushing rather than the 2 inch diameter that aluminum bushings are (out of the E-Body springs that came with the Caltracs).
My first thought was "Great, another delay" figuring I would have to order new bushings.
I decided it would be faster to dig out my small lathe to turn them down to the 1.5 inch diameter.
I got one done before I had to stop so we could go out for dinner and some grocery shopping.
It was midnight before we got back home so I'll be turning the other one down in the morning.
A pic showing the difference. (before and after)
Re: Caltrac installation, the next delay... [Re: SNK-EYZ] #1364386
01/12/13 08:09 AM
01/12/13 08:09 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Caltrac installation, the next delay... [Re: OhioMopar] #1364387
01/12/13 09:24 AM
01/12/13 09:24 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I used thin metal washer like a 1/16in from a toro 3100 greens mower let me know if you need any or you can stop by any golf course that uses toro.
Re: Caltrac installation, the next delay... [Re: Scamp408] #1364388
01/12/13 12:10 PM
01/12/13 12:10 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I am confused about two things.
1. Why would you use XHD springs with CalTracs? I have mono leafs so they will flex.
2. On my A body, I had no problems with spring eye bushing spacing. Just installed with the bushing and washer provided. Are B body springs different as far as front brackets or what?
Re: Caltrac installation, the next delay... [Re: babarracuda] #1364389
01/12/13 04:07 PM
01/12/13 04:07 PM
A Red State
A Red State
I went with the XHD Mopar springs because the car is primarily a street car that will get raced.
If it was just a race car I'd probably tub or mini-tub it and go with ladder bars rather than leaf springs at all.
The original factory b-Body springs had 2 inch diameter bushings in the front eyes.
The new replacement XHD B-Body springs are 1.5 inch diameter bushings, which is why I had to cut the aluminum bushings down.
I guess Ma Mopar felt they had to change the bushing size.
My original springs were shot, the only thing keeping the car level were the air shocks that were coming off.
I had planned on using the springs that came with the Caltrac but they were one inch shorter (E-Body).
My choices were skip the Caltracs and just go with Super Stock springs (and new front hangers) or just get some type of replacement springs and use the Caltracs.
I talk to a few buddies to get opinions and they thought the Caltrac option was a better choice.
Scott (Blues Cuda) is running Caltracs with the XHD Mopar springs and it seems to work for him.
I'm limited by what will fit in a stock 67 B-Body wheel well right from the start.
I guess I'll see how they work for me.
Re: Caltrac installation, the next delay... [Re: SNK-EYZ] #1364390
01/12/13 11:26 PM
01/12/13 11:26 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Rich-
I switched the Barracuda to monoleafs a year or so ago, but you'll be fine with the XHD leafs. Our '64 has Caltracs with XHD leafs and it can yield a 1.50 60ft on a 9" slick leaving off a footbrake.
