5 point harness #1364070
01/04/13 01:52 AM
01/04/13 01:52 AM
florida dade
cesar perez Offline OP
florida dade
need pictures and explanation on installing a 5 point harness with 8 point cage thanks
Re: 5 point harness [Re: cesar perez] #1364071
01/04/13 03:06 AM
01/04/13 03:06 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Just Google race harness installation.
Re: 5 point harness [Re: rowin4] #1364072
01/04/13 11:17 AM
01/04/13 11:17 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Use the NHRA rule book as your guide. It will help with the installation and then you will pass tech. I find the camlock style easier to buckle than the old lever style.
2011 Drag Pak Challenger
Re: 5 point harness [Re: rickseeman] #1364073
01/04/13 11:41 AM
01/04/13 11:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I like the cam lock also... can have the lower straps
hooked up in the lanes and at the last minute hook
up the shoulder straps....to the OP if your seat is
in the stock location you can use the stock floor mounts
for the 2 belts... the shoulder belts rap around the
cross bar... the anti dive belt you will have to add
a plate to reinforce the floor
