Re: Please help! No oil pressure!
[Re: shamefulcuda]
#1364061
01/05/13 01:09 AM
01/05/13 01:09 AM
Posts: 4,320 Prospect, PA
BSB67
Prospect, PA
Last night, you pulled the oil pan, checked all of the bearings and drove it today?
I must be getting old.
And if the front plug was out, you were not getting oil to the bearings.
[Re: BSB67]
#1364062
01/05/13 03:17 AM
01/05/13 03:17 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
It's his game, let him roll his dice.
[Re: 64Post]
#1364063
01/05/13 03:28 AM
01/05/13 03:28 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Back in the 70s I installed a fresh 440 in a 68 GTX, and had the same problem. A chevy shop had hot tanked the motor and not replaced the plugs.. The customer drove the car for a week before we found the problem..No oil gauge..(back when there was one car and you drove it or didnt get to work). No long term problems with that engine..Ran High 12s the next summer..
[Re: Dodgem]
#1364066
01/05/13 12:04 PM
01/05/13 12:04 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I was following this but someone had already suggested looking for a missing plug. Glad you got it sorted before any major damage was done.
Scott
1969 Super Bee, 383/4 speed
[Re: 64Post]
#1364067
01/05/13 12:08 PM
01/05/13 12:08 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
He should go buy a lotto ticket.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: shamefulcuda]
#1364069
01/06/13 02:10 AM
01/06/13 02:10 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Don't forget that the rod bearing that takes a beating when there is no oil pressure is the top half, not the bottom half I made a rod bearing tap by running the oil level low on the first Mopar I owned, going up a hill and kick it down into passing gear and about halfway up the hill the oil light flickered and the rod tapping started I had pulled a small piece out of one of the rod bearing bottom half and it rolled up into wedge making a large slot in the center of the bearing, it went tap, tap, tap until I had them all replaced by a local shop I have since seen a lot of rod bearings become junk due to low or no oil pressure, I have had the oil bypass plug come out of two mtors in high gear above 5500 RPM, the oil pressures go away in a hurry, one time I had three upper bearing shells marked up and the other time it got all of them On the bad one I didn't have a oil light and kept my foot in it for the last three hundred feet, on the first one I heard the plug bounce off of the headers and looked down at the oil pressure gauge, it was dropping so I push the nuetral button (1963 Plymouth 426 M.W.) and turn the ignition switch off right away, three uppers still got damamged
