Re: Please help! No oil pressure!
[Re: shamefulcuda]
#1364040
01/04/13 01:25 AM
01/04/13 01:25 AM
RapidRobert
Need help fast
probably missing an oil gallery plug. Been on SB's for decades so I'm rusty on BB (but a 451 is in the works) but I think there's one under the timing cover & others will chime in with more info.
[Re: shamefulcuda]
#1364048
01/04/13 05:22 AM
01/04/13 05:22 AM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
do you have a bore scope?
You can remove the fuel pump and plate, and look in while priming the oil system.
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: shamefulcuda]
#1364052
01/04/13 04:29 PM
01/04/13 04:29 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
I had oil coming out in back but no actual pressure with gauge hooked up. Lets hope it's a front plug and not rear of motor behind flywheel as I have all my 4 speed stuff hooked up now. Do not want to tear apart whole motor obviously . I have no bore scope so I guess I'm tearing front of motor off today
Check your oil pressure gauge with some air pressure first now I have had a valve spring break while racing,it broke on the return road idling back to the pits, and that let a pushrod fall out of the drivers side which allowed that roller lifter to pop out of its lifter bore, which resulted in either zero or less than 10 lbs of oil pressure, I can't remember now exactly what the gauge read when I looked at it, it was low so I shut it off right away. This problem has me intriqued Please let us kow what you find BTW, I have also had the bypass valve in the BB oil pumps stick half way open due to a tiny bit of debris being caught between the valve and oil pump passge it rides in, new motors make metal while breaking in I wouldn't think that is your case do to swapping ol pumps but is is easy to ceck, take the pump off the motor and remove the plug and spring that holds the bypass valve in and point the passage down toward s the bench, table or floor and see if it will side out using ravity. It will be slow to slide out do to the oil in there but it should slide out easily. If it has to be sucked out of there with a magnet or tapping the cover on a hard surafce check it, the valve, and the bore real carefully for burrs or debris Let us know what you find ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#1364055
01/04/13 06:07 PM
01/04/13 06:07 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
He already put a new HV pump on it with the same result... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: shamefulcuda]
#1364057
01/04/13 08:24 PM
01/04/13 08:24 PM
draginmopars
smyrna,tn
I would pull the rocker arm shafts and check them. just to be sure there is no damage, from lack of oil.
hate to find out down the road.
Howard
