Carb Rebuild Kit Recommendation??? #1363900
01/03/13 05:15 PM
01/03/13 05:15 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I need to rebuild a 750 Holley DP that's been on the shelf for 10 years. Summit's website has 9 different kits listed for this carb by several different manufacturers. Can you guys recommend a decent one??
http://www.summitracing.com/search/depar...rd=holley%20kit
Re: Carb Rebuild Kit Recommendation??? [Re: mopowers] #1363901
01/03/13 05:38 PM
01/03/13 05:38 PM
Toronto
mshred Offline
mshred  Offline
Toronto
my brother did an 850 with the first one on that list, the holley carb renew kit, and as far as I know had no problems
Re: Carb Rebuild Kit Recommendation??? [Re: mshred] #1363902
01/03/13 07:20 PM
01/03/13 07:20 PM
Az
Crizila Offline
Crizila  Offline
Az
Ya, stick with the Holley kit if you can. Better quality all around and generally shorter shelf time than others.
Fastest 300
Re: Carb Rebuild Kit Recommendation??? [Re: Crizila] #1363903
01/03/13 08:16 PM
01/03/13 08:16 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
The AED kits are quality and complete.
Had great luck with them
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Carb Rebuild Kit Recommendation??? [Re: moparts] #1363904
01/03/13 08:34 PM
01/03/13 08:34 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I sell both the Holley kit,{#37-1544} and the Proform kit,{#67222},both are very complete and haven't had any problems with either,both have the re-usable blue gaskets and come with 2 30cc pumps and 1 50cc accelerator pump.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Carb Rebuild Kit Recommendation??? [Re: moparts] #1363905
01/04/13 01:05 AM
01/04/13 01:05 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have also been using the AED kits for a while now. They make one kit that is especially handy for going through an older carb. It has head head fuel bowl screws to replace the older slotted pan head stuff.
http://www.summitracing.com/parts/aed-41501/overview/
One thing I ponder every time I order a kit is why they don't have different p/n's for different power valves. Not everybody wants a 6.5 or whatever it is that comes in the kit.
Re: Carb Rebuild Kit Recommendation??? [Re: Jeremiah] #1363906
01/04/13 11:15 AM
01/04/13 11:15 AM
Az
Crizila Offline
Crizila  Offline
Az
Wow! They do look like nice kits. Gotta start trying them.
Fastest 300
Re: Carb Rebuild Kit Recommendation??? [Re: Crizila] #1363907
01/05/13 09:58 AM
01/05/13 09:58 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I used the jegs kits once and the pump diaphrams leaked I had to peen the rivit more to seal it. It was a overnight weep.
