Page 1 of 3 1 2 3
Flow testing carburetors... * DATA ADDED * #1363862
01/03/13 03:48 PM
01/03/13 03:48 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I'm considering making a fixture for doing airflow testing of carburetors on my lil' SuperFlow 110. However, I'm wondering if there's really valid data to be gained from this, especially since most of the testing would be restricted to one venturi at a time, or two at a time at most.
I know that wet flow #s can't really be calculated from dry flow since different booster designs (e.g. downleg vs. annular) have a varying effect / impact on the wet flow characteristics.
Is there still a benefit to dry-flow comparisons of different carbs and / or checking booster draw rates for consistency across all the venturi? Anything else that can be gleaned from this method of testing?
If not, I'll save the time & $$$ and skip on the fixture.
Re: Flow testing carburetors... [Re: BradH] #1363863
01/03/13 04:10 PM
01/03/13 04:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use to have my carbs. flow tested by a shop that had two Superflow benches, 110 and a 600. Origianlly they would test the carbs. on the 110 at 5 inches, one venturi at a time. That machine broke so they strated flowing them on the 600 through all venturis at once. I don't remember having the same carb. tested on both but I did find out on the 600 bench that my new,to me, at that time, Holley 950 HP did not flow 950 CFM, more like 880 CFM, my stock Holley 4781-2 850 DP flowed like 910 and a a freinds BG 750 stage three heavily modified 750 flowed 920 CFM I guess the message is they(benches) are both measuring devices, what you do with the results is important to those wanting them Inforamtion can be dangerous, lack of information can be more dangerous
Re: Flow testing carburetors... [Re: BradH] #1363864
01/03/13 04:10 PM
01/03/13 04:10 PM
SoCal
Brian Hafliger Offline
SoCal
There are things you can find, like a booster maybe a little crooked causing flow loss. I know some guys will flow 1 venturi with a manometer hooked to the main flow well with a little tube to see how each booster is working compared to the others. It's also a nice way to do a little bit of deburring in the venturi and bores and making sure they all a close to one another in flow.
Brian Hafliger
Re: Flow testing carburetors... [Re: Brian Hafliger] #1363865
01/03/13 10:37 PM
01/03/13 10:37 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I spent far too much time doing this type of testing on the annular booster setup I made for AVS carbs.
http://www.nzmoparforum.co.nz/index.php?topic=7933.0
it did work but I can sum it all up for you in about 2 lines
Carb flow & jet signal are a balancing act & more often than not if you change one you will compromise the other.
eg, tidying up your booster leg or venturi for better flow lowers the signal to the jet while increasing the signal to the jet with annular or skirted boosters will decrease the flow of the carb.
Re: Flow testing carburetors... [Re: BradH] #1363866
01/04/13 11:55 AM
01/04/13 11:55 AM
BradH Offline OP
BradH  Offline OP
I already have a separate manometer that I've used for some limited port velocity testing, so I'm good there.
I haven't decided exactly what configuration I'm going to build; I have a couple of different approaches in mind, neither of which are that complex. Regardless, the total cost to make something functional should be far less $$$ than what the commercially available carb flow-test fixtures would cost to purchase.
Also, I have an idea or two from some stuff I've read that makes me think using a fixture that bolts directly to the deck of the flow bench isn't the best way to test. Instead, locating the fixture on top of a cylinder head adapter of adequate bore size (looks like my 4.375" bore adapter is about right) to give the carb something more akin to an intake manifold plenum to discharge into before dropping into the flow bench's "black hole" is supposed to be better for pressure recovery characteristics.
Re: Flow testing carburetors... [Re: BradH] #1363867
01/04/13 03:45 PM
01/04/13 03:45 PM
Let me throw you a curve on how some of the NHRA class racers have flow tested there heads, intake manifolds and carbs. Bolt the head to the bench, bolt the intake to the the head and cover most of the other intake ports( figure out which other intake valves are open and how much there opened compared to the port your flowing off of for your tests and restrict that port window that much ) and then bolt the carb. on the intake. Do more than one port on both sides and go from there
Re: Flow testing carburetors... [Re: Cab_Burge] #1363868
01/07/13 06:53 PM
01/07/13 06:53 PM
BradH Offline OP
BradH  Offline OP
FWIW, I have started to piece together a carb flow-test fixture. "440 Jim" has fabbed a part for it that should pretty much complete the assembly once it arrives.
I have a few different 4150-type carbs to try and am hoping the #s make some sense, despite the tests being run on a low-capacity bench. My baseline carb is a basic 4781 Holley 850 DP w/o a choke plate; I'll test some other stuff after seeing what sort of #s and consistency I get trying out the 850.
Re: Flow testing carburetors... [Re: BradH] #1363869
01/09/13 12:06 PM
01/09/13 12:06 PM
BradH Offline OP
BradH  Offline OP
Fixture completed... now just need some time to throw some carbs on the bench and see what they do.
Re: Flow testing carburetors... [Re: BradH] #1363870
01/09/13 06:01 PM
01/09/13 06:01 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brad,
i look forward to the results.especially as i may step up my carb when the new heads,for me, go on my 440
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Flow testing carburetors... [Re: BradH] #1363871
01/10/13 02:49 PM
01/10/13 02:49 PM
NC
440Jim Offline
440Jim  Offline
NC
Post some pictures of the complete setup.
Re: Flow testing carburetors... [Re: 440Jim] #1363872
01/10/13 03:42 PM
01/10/13 03:42 PM
BradH Offline OP
BradH  Offline OP
That's the plan... especially when I have some results to post, too.
I'm really interested in seeing if my approach to testing (using an air bell on top of the carb + mounting the fixture to a cylinder head bore adapter as I mentioned previously) helps show up more significant differences in flow results when testing different size venturi sleeves w/ my BG carbs.
Example: When Dwayne Porter posted carb flow test results waaaaaay back when from his old SF-110, his dry vs. calc'd wet flow #s were:
1.562" venturi + downleg = 1000.7 dry / 920.6 calc'd wet
1.562" venturi + annular = 980.5 dry / 902.0 calc'd wet
1.425" venturi + downleg = 964.1 dry / 886.9 calc'd wet
In comparison, BG's published wet flow #s for those same three configurations were:
1.562" venturi + downleg = 1084
1.562" venturi + annular = 875 (not a misprint; annular boosters have a much bigger impact on wet flow ratings)
1.425" venturi + downleg = 980
Even if BG's wet flow #s can't be compared to anything I might find, I was really surprised at how much smaller the gains were w/ Dwayne's tests when comparing the 1.562" vs 1.425" sleeves w/ downleg boosters...
Re: Flow testing carburetors... [Re: BradH] #1363873
01/11/13 01:54 PM
01/11/13 01:54 PM
BradH Offline OP
BradH  Offline OP
Although I have taken some pics, I haven't downloaded them from the digi-cam, yet. In the mean time, here's some data from what I've tested:
Carb ------------------------------------------------------------ (TM) --Dry Flow -- Calc'd Wet
Holley 3310-2 with choke ----------------------------------- (A) ----- 796.6 ----- 732.9
Holley 3310-2 with choke ----------------------------------- (B) ----- 811.6 ----- 746.7
Quick Fuel “950” 1.45 v body on Demon RS baseplate -(C) ----- 964.4 ----- 887.2
Quick Fuel “950” 1.45 v body on Demon RS baseplate -(D) ----- 963.0 ----- 886.0
BG (Gold Claw / Demon RS) 1.425 venturi sleeve ------ (C) ----- 960.4 ----- 883.6
BG (Gold Claw / Demon RS) 1.425 venturi sleeve ------ (D) ----- 958.1 ----- 881.5
BG (Gold Claw / Demon RS) 1.500 venturi sleeve ------ (C) ----- 982.9 ----- 904.3
BG (Gold Claw / Demon RS) 1.500 venturi sleeve ------ (D) ---- 1001.3 ----- 921.2
BG (Gold Claw / Demon RS) 1.562 venturi sleeve ------ (C) ----- 994.1 ----- 914.6
BG (Gold Claw / Demon RS) 1.562 venturi sleeve ------ (D) ---- 1012.0 ----- 931.0
Test Methods (TM):
1. Method “A” means this test was of a single primary bore AND then a single secondary bore with the results being added together and the sum multiplied x 2 for a Total Dry Flow #
2. Method “B” means this test was of both primary bores AND then both secondary bores with the results being added together for a Total Dry Flow #
3. Method “C” means this test was of a single bore (either primary OR secondary since the venturi have symmetrical entries) and multiplied the result x 4 for a Total Dry Flow #
4. Method “D” means this test was of either both primary OR both secondary bores (all venturi have symmetrical entries) and multiplied the result x 2 for a Total Dry Flow #
Other comments:
A. Not sure about the discrepancy between why the “A” and “B” results for the Holley 3310-2 varied as much as they did. The primary bore(s) results were virtually identical with both methods; all the variation was experienced during the tests of the secondary bores. I've read where some carbs when testing multiple venturi at the same time show better results than trying to combine the results of the individual venturi... this seems to be an example of that.
B. Test Methods “B” and “D” required lowering the test pressure significantly due to the small capacity of my SF-110. However, trying to test the two highest-flowing combinations using Method “D” required dropping the test pressure so low that I believe that lower pressure introduced a level of inaccuracy not experienced with the other tests.
C. The Calc'd Wet Flow results are simply the Total Dry Flow #s x .92 to subtract some flow for a theoretical 12.5:1 A/F ratio. I have no idea how close this comes to the reality of actually wet-flowing a carb, but it's something of an industry standard. I also suspect that – if it's an "in the ballpark" correction value – that .92 adjustment probably doesn't work for something like an annular booster which has different atomization characteristics that “use” more of the available airflow.
D. The Total Dry Flow #s posted include a 2% temperature correction (reduction) factor on my flow bench for intake results. If you want the “raw” Dry Flow #s, take my Total Dry Flow # and divide by .98 to get the pre-correction #. Example: 982.9 + .98 = 1003.0
E. The Demon RS 1.75” baseplate used for testing the Quick Fuel main body and the various BG (Gold Claw / Demon RS) venturi combinations has slabbed throttle shafts which are supposed to be worth 20 +/- cfm over standard “round” throttle shafts used by most Holley carbs, Proform carbs, Mighty Demon, etc. Quick Fuel uses a similar slabbed throttle shaft with their Q-Series and Race Q carbs.
F. I have no idea how BG came up w/ the wet flow #s they published when the Gold / Silver Claws came out (see the #s I listed in an earlier post on this thread). I know my test equipment is freakin' primitive, and maybe not having a "big gun" flow bench is skewing the peak #s lower for the larger venturi combinations, but...
Re: Flow testing carburetors... [Re: BradH] #1363874
01/11/13 02:54 PM
01/11/13 02:54 PM
NC
440Jim Offline
440Jim  Offline
NC
Great post.
As I read it,
Method A & C blocked off 3 of 4 venturii
Method B & D blocked off 2 of 4 venturii
What were the typical test pressure drops?
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363875
01/11/13 03:24 PM
01/11/13 03:24 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
When would it be important to flow a carburetor? I don't mean to sound ignorant. I'm just trying to understand the purpose.
Re: Flow testing carburetors... [Re: 440Jim] #1363876
01/11/13 03:26 PM
01/11/13 03:26 PM
BradH Offline OP
BradH  Offline OP
As I read it,
Yep.
I was pulling 10"-9" for single-bore tests and 4"-3" for 2-bore tests... until I tried the 1.50+" venturi configurations. I couldn't even get a solid 3" reading and had to back it down to a 2.5"...
It was like that scene in "Jaws" when they finally see the Great White up close for the first time and somebody says "We're gonna need a bigger boat." At that point I was really thinking I needed a bigger flow bench.
Re: Flow testing carburetors... * DATA ADDED * [Re: MPerry] #1363877
01/11/13 03:29 PM
01/11/13 03:29 PM
BradH Offline OP
BradH  Offline OP
... I'm just trying to understand the purpose.
Purpose? I'm a gearhead w/ a flow bench! I don't need a purpose...
Re: Flow testing carburetors... * DATA ADDED * [Re: BradH] #1363878
01/11/13 03:39 PM
01/11/13 03:39 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Here I am think there was some dark hidden secret.
Like matching 2 carbs for a 2 x 4 tunnel ram.
Re: Flow testing carburetors... * DATA ADDED * [Re: MPerry] #1363879
01/11/13 05:07 PM
01/11/13 05:07 PM
BradH Offline OP
BradH  Offline OP
... some dark hidden secret.
Oh, that... yes, there is one.
Re: Flow testing carburetors... * DATA ADDED * [Re: MPerry] #1363880
01/12/13 10:32 AM
01/12/13 10:32 AM
NC
440Jim Offline
440Jim  Offline
NC
I can think of some.
1) Rating actual carb air flow
2) Gathering data to tweak a carb to make all the venturii flow the same and give the same booster signal
3) Improving carb air flow, comparing changes
Re: Flow testing carburetors... * DATA ADDED * [Re: 440Jim] #1363881
01/12/13 01:59 PM
01/12/13 01:59 PM
BradH Offline OP
BradH  Offline OP
Yep.
My primary interest for this round of tests was seeing what sort of quantifiable flow improvements resulted from increasing the venturi size. I know from on-track testing that "bigger" carbs that may show HP improvements on the dyno don't always translate to improvements on the track.
Gaining ~ 20 cfm going from 1.425" to 1.500" venturi looks like better potential for "real world" improvement than only gaining 10 cfm from stepping up yet again from 1.500" to 1.562", assuming this data is legit for the purpose of selecting the carb size for my 452.
Page 1 of 3 1 2 3
