"A" body over center spring #1363754
01/03/13 12:26 PM
01/03/13 12:26 PM
Motor City
73Convertriple Offline OP
Motor City
Spring has a short and a long straight portion before the hook. Long end on pedal or stationary rear location, and open end of hook up or down?
thanks in advance
73 dart sport 340 4speed
Re: "A" body over center spring [Re: 73Convertriple] #1363755
01/03/13 03:47 PM
01/03/13 03:47 PM
Motor City
Motor City
Anyone out there got a 4 speed "A" body ? I need to reinstall the spring and want to make sure I'm puting it back in the right orientation. Not fun getting them in or out.
Re: "A" body over center spring [Re: 73Convertriple] #1363756
01/03/13 04:39 PM
01/03/13 04:39 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: "A" body over center spring [Re: 73Convertriple] #1363757
01/03/13 04:40 PM
01/03/13 04:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Should be fairly easy to tell which way it goes , going off my sometimes foggy memory the long end of the springs goes to the peddle , open end down .
Did you try to find a pedal assembly for sale on ebarf ?
tree'd by the guy above me , I see the open end is up , which makes sense ... It was a foggy memory ...
Re: "A" body over center spring [Re: JohnRR] #1363758
01/04/13 11:39 AM
01/04/13 11:39 AM
Motor City
Motor City
thanks for link to brewers site appears to be long end forward and open hook end up.
Re: "A" body over center spring [Re: 73Convertriple] #1363759
01/04/13 11:54 AM
01/04/13 11:54 AM
P
Pntastar69 Offline
Pntastar69  Offline
P
Re: "A" body over center spring [Re: 73Convertriple] #1363760
01/09/13 07:28 PM
01/09/13 07:28 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
On 69 Barracuda 340 4-sp factory installation, long/straight end of spring goes toward firewall. Curved ends are down.
