Weight difference between aluminum and cast iron intake #1363718
01/03/13 12:23 PM
01/03/13 12:23 PM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
I'm putting an aluminum 6 Pack intake on my car and was wondering what the weight difference is between that and the cast iron version.
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363719
01/03/13 12:47 PM
01/03/13 12:47 PM
MA
steve70 Offline
steve70  Offline
MA
I'm not sure what the cast iron intake weighs but aluminum is roughly 1/3 that amount.
1970 Challenger T/A 4 speed
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363720
01/03/13 01:25 PM
01/03/13 01:25 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
some of us have been wondering that for quite a while; now you can weigh both and let us know!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Weight difference between aluminum and cast iron intake [Re: steve70] #1363721
01/03/13 01:52 PM
01/03/13 01:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I had a cast iron 6pk on my 69 RR , when I removed the intake the front end lifted up about a 1/2" .
Re: Weight difference between aluminum and cast iron intake [Re: JohnRR] #1363722
01/03/13 02:29 PM
01/03/13 02:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
only laughing because it sounds true
Re: Weight difference between aluminum and cast iron intake [Re: DPelletier] #1363723
01/03/13 03:05 PM
01/03/13 03:05 PM
Orleans, Ontario
Orleans, Ontario
I don't have a cast iron one otherwise I would.
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363724
01/03/13 03:22 PM
01/03/13 03:22 PM
DPelletier Offline
DPelletier  Offline
Darn. Well, weigh yours and post it and maybe someone will weigh their cast iron job. I should have, but it's bolted to the engine now.
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363725
01/03/13 06:24 PM
01/03/13 06:24 PM
AndyF Online content
AndyF  Online Content
I show the weights of a bunch of different engine parts in my B-body book. I tried to take pictures and get weights for all of the common "bolt on" parts.
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363726
01/03/13 07:40 PM
01/03/13 07:40 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cast iron = 38.6 lb
6Pk Alum. = 22.2 Lb
However, if you are looking at overall weight savings, the three Holleys weigh considerbly more than an AFB/AVS, closing the weight difference gap.
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363727
01/03/13 07:46 PM
01/03/13 07:46 PM
North Central USA (MN-WI area)
MuscleMopars Offline
Cast iron = 38.6 lb
6Pk Alum. = 22.2 Lb
I think he wants to know the weight difference between a cast iron 6 pack intake and an aluminum 6 pack intake. Both would have the 3 2bbl Holley carbs...
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: Weight difference between aluminum and cast iron intake [Re: MuscleMopars] #1363728
01/04/13 12:18 AM
01/04/13 12:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cast iron = 38.6 lb
6Pk Alum. = 22.2 Lb
ooops, my bad
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363729
01/04/13 06:29 PM
01/04/13 06:29 PM
Orleans, Ontario
Orleans, Ontario
Weighed on my house scale as pictured, it weighs 42 lbs.
If aluminum is .39 the weight of cast iron as stated above, then a similar equipped cast iron intake should weigh:
42 lbs
----- = 107 lbs.
.39
Right?
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363730
01/04/13 07:49 PM
01/04/13 07:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Weighed on my house scales as pictured, it weighs 42 lbs.
42 lbs
----- = 107 lbs.
.39
Right?
No.
Mine weighs about 39.5 lbs intake and carbs and fuel line (w/o kick-down and throttle bracket)
So, using your 42 lbs:
22/.39 = 56 for cast iron intake.
Carbs, brackets and fuel line weight about 20 lbs.
about 75ish pounds total
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363731
01/05/13 01:10 AM
01/05/13 01:10 AM
Orleans, Ontario
Orleans, Ontario
I don't think carbs and fuel lines weigh 20 lbs.
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363732
01/05/13 01:17 AM
01/05/13 01:17 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If the intake weighs 22 lbs without the carbs, and it 42 with the carbs, where do you think the other 20 lbs comes from? Okay, 18 lbs.
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363733
01/05/13 01:21 AM
01/05/13 01:21 AM
Orleans, Ontario
Orleans, Ontario
You're saying it weighs 22 lbs without the carbs. Do you know that for a fact? I'm saying I don't think the carbs weigh 20 lbs.
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363734
01/05/13 03:53 AM
01/05/13 03:53 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
ooops, my bad
Huh.
No need to apologize. That's a bit of an eye opener for me, thanks for bringing that up. Six-Pack breather is no feather-weight either........
Mo' Farts
Moderated by "tbagger".
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363735
01/05/13 10:18 AM
01/05/13 10:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nope, just made it up, 22.2 lbs
Re: Weight difference between aluminum and cast iron intake [Re: BSB67] #1363736
01/05/13 11:27 AM
01/05/13 11:27 AM
Orleans, Ontario
Orleans, Ontario
Then what's your point? I could also guess at the weight of a cast iron intake but I want the actual weight.
If anyone has a cast iron intake with mounted carbs that can be weighed then that would be close.
Doesn't anyone have a cast iron intake that can be weighed?
Re: Weight difference between aluminum and cast iron intake [Re: moparcanuk] #1363737
01/05/13 12:59 PM
01/05/13 12:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Didn't you see his post above giving the weight of the alum 6 pk manifold and a cast iron 4bbl ?
The cast iron setup with carbs does not weigh 107 is what he is saying.
I'm going to ask a real STUPID question ... why does it matter ? If the iron weighs only 10 lbs more are you going to trade the alum. one for an iron one ? The iron one is not correct for 69 ... if that matters ....
