300M heater stuck at max heat/defrost mode #1363541
01/03/13 02:20 AM
01/03/13 02:20 AM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
Hey all the heater in my 2000 300M just recently got stuck at max heat and in defrost mode. The digtal display lights show the mode changing but it only blows hot air on the windshield. The display lights also show the temp changing up/down when I adjust it but the temp stays and full heat . The fans speeds works fine and the A/C is not on while the defrost is blowing the heat if that makes any difference. My 103 mile drive to work every morning with freezing feet/hot face is getting old quick ! Any ideas where to start looking? Thanks for your help
Re: 300M heater stuck at max heat/defrost mode [Re: 392charger] #1363542
01/03/13 03:59 AM
01/03/13 03:59 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Have you tried this?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 300M heater stuck at max heat/defrost mode [Re: Evil Spirit] #1363543
01/03/13 12:46 PM
01/03/13 12:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Doing that three button test would occasionally fix the A/C in my 2002 Concorde Limited.
Do that and find out what code it gives you. I have a list of them at home.
Problems with the auto A/C is one of the reasons I sold my Concorde. That stuff was extremely expensive and has been discontinued.
- Stu Harmon
Re: 300M heater stuck at max heat/defrost mode [Re: feets] #1363544
01/03/13 06:28 PM
01/03/13 06:28 PM
Rancho Cucamonga,Ca
3
Rancho Cucamonga,Ca
Thanks for the help guys. I just tried the code reading trick and it says code #24. Any ideas?
Re: 300M heater stuck at max heat/defrost mode [Re: 392charger] #1363545
01/03/13 06:32 PM
01/03/13 06:32 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
24 is the mode door actuator failure.
It means you're stuck with air blasting out of the current vents.
The ATC and manual AC systems had different actuators. If I recall correctly, replacing them requires a dashectomy.
The actuator I needed was discontinued.
- Stu Harmon
Re: 300M heater stuck at max heat/defrost mode [Re: feets] #1363546
01/04/13 07:20 PM
01/04/13 07:20 PM
Rancho Cucamonga,Ca
3
Rancho Cucamonga,Ca
I noticed after I did the code reading trick that the heat can now be adjusted up/down. That's an improvement but the vents are still stuck at defrost mode. Does this mean anything? Am I still looking at a dashectomy?
Re: 300M heater stuck at max heat/defrost mode [Re: 392charger] #1363547
01/05/13 12:57 AM
01/05/13 12:57 AM
ND
dodgedon Offline
dodgedon  Offline
ND
I just did this on my 2000 300M. I had code #24 Mode door actuator.
Bought the part at the dealer.
I installed mine through the radio opening. Didnt have to take the dash all apart. Google it and you will find pictures info and a youtube video on how to fix it.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
