Double Neutral valvebodys #1363466
01/03/13 12:27 AM
01/03/13 12:27 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey Guys,
Anybody got any thoughts on the double neutral valvebodys? They seem to be all the rage in our local Super Stock class...at least for the Chevys and Fords.... the idea seems sound but havent seen them too much in 727s...
Anybody using one? How do you like it?
Re: Double Neutral valvebodys [Re: WH23H6] #1363467
01/03/13 05:25 AM
01/03/13 05:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using the A&A Ulimate brake with the safe neutral after 3rd. i like it. it's a brilliant holeshooter brake, ask the guy i just beat.
edit: for those who are wondering. that guage is hooked up to the trans so i can check line pressure.
AND i'm RHD incase you were wondering.
Re: Double Neutral valvebodys [Re: rebel] #1363468
01/03/13 04:51 PM
01/03/13 04:51 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
I use one from Pro Trans, works great.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Double Neutral valvebodys [Re: rebel] #1363469
01/04/13 12:43 AM
01/04/13 12:43 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
I notice you have the same shifter as I use... I also use an air shifter....I was kinda wondering how that would work? I can't see how it would hook up?
Thanks,
Re: Double Neutral valvebodys [Re: WH23H6] #1363470
01/04/13 12:52 AM
01/04/13 12:52 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
pretty sure you still need to manually shift it into clean neutral. the precision performance products shifters are really nice.
Re: Double Neutral valvebodys [Re: prochargedhemi] #1363471
01/04/13 01:38 AM
01/04/13 01:38 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Thanks.. I may have to look into it...not sure why more people dont use these safty valvebodies...
Re: Double Neutral valvebodys [Re: WH23H6] #1363472
01/04/13 04:10 PM
01/04/13 04:10 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Do you use these with alloy rod motors? Heard they help the rods live a little longer but I'd guess you better have good brakes
Re: Double Neutral valvebodys [Re: Tig] #1363473
01/06/13 12:13 AM
01/06/13 12:13 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
No Kidding!
Re: Double Neutral valvebodys [Re: WH23H6] #1363474
01/06/13 12:26 AM
01/06/13 12:26 AM
Washington
SuperStock68Dart Offline
Washington
Call Pro Trans.....and if you don't need the brake, he will sell you one with just the "clean" neutral.
Re: Double Neutral valvebodys [Re: SuperStock68Dart] #1363475
01/06/13 11:57 AM
01/06/13 11:57 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Really!?
That's what I've been looking for
Re: Double Neutral valvebodys [Re: roadhazard] #1363476
01/06/13 05:40 PM
01/06/13 05:40 PM
Washington
Washington
Yes! It's what I use in my car.....I think they're around $300.00 and it works great!!
Re: Double Neutral valvebodys [Re: SuperStock68Dart] #1363477
01/06/13 07:25 PM
01/06/13 07:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Good to hear That seems like a pretty fair price. I assume it is a LBA valve body?
What shifter are you using with that?
Re: Double Neutral valvebodys [Re: WH23H6] #1363478
01/06/13 10:46 PM
01/06/13 10:46 PM
Temperance, MI
P
P
Temperance, MI
they are more common then you may think.
Re: Double Neutral valvebodys [Re: prochargedhemi] #1363479
01/07/13 12:14 PM
01/07/13 12:14 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I am debating putting one in my new car. Problem is a have a really expensive brake already in the trans. What is the real advantage to these? Saving aluminum Rods?
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Double Neutral valvebodys [Re: HemiDart68] #1363480
01/07/13 12:36 PM
01/07/13 12:36 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
using the engine as a braking mechanism is THE most expensive brake system you can have. At 8600+ RPM, I would rather replace disc pads a couple times vs repairing the holes in the sides of the block from stretching the steel/aluminum rods....nothing but clean nuetrals on our stuff for over 10 years, we use the Pro Trans valve bodies.
Be a Rebel- Break the Laws of Physics!
Re: Double Neutral valvebodys [Re: roadhazard] #1363481
01/07/13 04:48 PM
01/07/13 04:48 PM
Washington
Washington
Yes it's LBA and I use the Precision Performance Products shifter.
