1965 B-Body Front Suspension Drawing #1363351
01/02/13 09:33 PM
01/02/13 09:33 PM
Arizona
410mopar Offline OP
410mopar  Offline OP
Arizona
I need a drawing (blueprint) of the front suspension. I need to know the mounting positions of all the parts, upper and lower arms, shock upper and lower mount positions. Any help appreciated.
Re: 1965 B-Body Front Suspension Drawing [Re: 410mopar] #1363352
01/02/13 10:59 PM
01/02/13 10:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Good luck, closest I've ever seen is the drawings in the FSM not sure that'll have everything you need.
Don't be the exception.
Re: 1965 B-Body Front Suspension Drawing [Re: 410mopar] #1363353
01/02/13 11:40 PM
01/02/13 11:40 PM
AndyF Online content
AndyF  Online Content
Fat chance of finding a drawing like that unless you're willing to pay for it.
Re: 1965 B-Body Front Suspension Drawing [Re: AndyF] #1363354
01/03/13 12:16 AM
01/03/13 12:16 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
how much of that info might have been supplied with a frame alignment machine for the purpose of unibody alignment?
That probably shows something but not all the measurements your looking for.
Re: 1965 B-Body Front Suspension Drawing [Re: PHJ426] #1363355
01/03/13 12:33 AM
01/03/13 12:33 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Not much info. Those charts don't define the suspension pick up points.
I assume the O.P. wants to plot the suspension geometries on paper or proabably a computer program.
Break out your rulers, calipers, plumb bobs, height indicators, etc, etc..! Actually you should check the circle track parts industry. They may sell some tools to do this type of measuring. I helped a guy do it to chassis years ago, but don't remember the brands or names of the equiptment.
It's much harder to do to a stock bare chassis compared to a race car bare chassis.
Re: 1965 B-Body Front Suspension Drawing [Re: 410mopar] #1363356
01/03/13 02:07 AM
01/03/13 02:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: 1965 B-Body Front Suspension Drawing [Re: 410mopar] #1363357
01/03/13 01:23 PM
01/03/13 01:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Stuff a 69 k frame under the car if you're concerned about handling. It will move the engine back and down but the suspension geometry stays the same.
As a bonus you will get the improved idler arm mount with top and bottom brackets. The 65 uses a cantilevered bottom bracket without any support on top. It just kinda flaps around under stress.
- Stu Harmon
Re: 1965 B-Body Front Suspension Drawing [Re: feets] #1363358
01/05/13 12:33 PM
01/05/13 12:33 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The Firm Feel ball bearing idler kit mitigates this to a considerable extent.
Rick
Re: 1965 B-Body Front Suspension Drawing [Re: Rick_Ehrenberg] #1363359
01/05/13 01:20 PM
01/05/13 01:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Rick
True but that won't move 700+ lbs of weight in a favorable direction.
- Stu Harmon
