Re: Diff Set-up question???
[Re: mopowers]
#1363230
01/02/13 07:51 PM
01/02/13 07:51 PM
Posts: 75,017 U.S.S.A.
JohnRR
U.S.S.A.
I'm getting ready to start assembly of my 489 case diff. I have the solid spacer/shims for setting pinion bearing preload. Is this something I can do first, since I may have to trial and error the pinion depth a bit to get it right? Will dis-assembly to change the pinion depth shims impact the pinion bearing preload once I have that where I want it???
Or is it better to make sure the pinion depth is correct before attempting to figure out the shim pack for pinion bearing preload?
The pinion preload will not change because the bearings preload is the distance between the the inner race of the 2 bearings which is determined by the spacer ... that distance is not affected by the pinion depth. If it were a 742 you would set preload after you set the pinion depth. 741 has a spacer that I'm 99.9% sure pushes against the inner bearing race like the 489 crush sleeve.
Lastly, does the pinion nut need to be torqued fully to take a pinion bearing preload measurement?
YES
[Re: mopowers]
#1363232
01/02/13 08:41 PM
01/02/13 08:41 PM
JohnRR
U.S.S.A.
So, basically it's ok to set pinion bearing preload first??? It just seems bass ackwards to set everything else first, then take it apart to set pinion bearing preload, only to reinstall the carrier and re-set the backlash/carrier bearing preload with the spinning adjusters. ya know???
The problem with the 489 is because the crush sleeve goes in from the pinion head end and the crush sleeve is a one time use part. The factory uses different tools to set the gears that basically tell the assembler what shim to use and it's pretty much spot on best I can figure.
The 741 and 742 shims and stuff go in from the yoke end so it's not such a big deal.
[Re: CSK]
#1363238
01/02/13 11:29 PM
01/02/13 11:29 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Set the pinion depth before setting the pinion bearing preload Make sure the pinion bearing preload is more(tighter) than it should be when setting the pinion depth
cab is correct ,you HAVE to set pinion depth 1st,then preload
Why is that? If using a solid spacer (which I am) and shims, Once I set the pinion preload, would it change once I start adding or subtracting depth shims under the inner pinion bearing. I would tend to think it would stay the same. I'll be using a dummy set-up bearing for depth btw.
[Re: mopowers]
#1363239
01/03/13 12:13 AM
01/03/13 12:13 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
Why change the prelaod shims 88 times when you can do it once or twice Are you using a pinion depth tool or doing it off of the pattern?
[Re: mopowers]
#1363241
01/03/13 12:26 AM
01/03/13 12:26 AM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
it depends how tight the outer bearing is on the pinion gear
[Re: BLACKHEMIRR]
#1363242
01/03/13 12:34 AM
01/03/13 12:34 AM
JohnRR
U.S.S.A.
Thanks for the recalibration of my memory. It's the Danas that have the shims behind the outer race. Next time I'll brush-up before I chime-in.
I foggily remember taking apart a 489 that had them under the race once .
[Re: mopowers]
#1363243
01/03/13 12:36 AM
01/03/13 12:36 AM
JohnRR
U.S.S.A.
Stupid question time. Do you need to pull the pinion too change the preload shims when using a solid spacer in the 489 case?
As said it depends on how tight the outer bearing fits on the pinion stem , BUT the shims go between the outer bearing and the spacer so you shouldn't have to.
[Re: mopowers]
#1363244
01/03/13 12:38 AM
01/03/13 12:38 AM
JohnRR
U.S.S.A.
the preload is set with the spacer between the 2 bearings and nothing else , once it's set correctly it never changes no matter how many times you change the depth shim.
[Re: JohnRR]
#1363245
01/03/13 12:45 AM
01/03/13 12:45 AM
Posts: 4,872 connecticut
pnypwr
connecticut
you cant set preload on a dummy bearing, the rotational torque will be different between a new bearing and old, set your depth, dissassemble set your preload. the carrier is not installed when checking preload on the pinion. then install the carrier, set your backlash and check the pattern again. all 8 3/4s ive ever been in shim the pinion under the bearing, every dana except the 35 shims the pinion under the race, either way will work,
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1363246
01/03/13 01:14 AM
01/03/13 01:14 AM
mopowers
Sac, CA
Re-read my post. I said I'll be using a dummy bearing for setting DEPTH. I don't have a depth gauge, so I'll be setting it by pattern, which means I'll likely have to take it apart a bunch of times.
Seems to me that you can do it either way. Preload first, or depth first. Does it really matter???
