check the acclrator pump,it might be going south
I had trouble with 2 carbs latly with the cheap gas they are clogging up air bleeds and the floats are sticking
may want to check the condenser if it has points,mine did that also,start,idel,would throttle blip fine but would shake pop and barly go when in gear
50$ service bill for a 50 cent part,first place I look now
may check your cap and rotor,wires and plugs while your at it
has it been sitting around some?,thats when I find the gas is going bad fast and the trouble started with mine
but most likly the pump in the carb,look for a good squrt of gas when you pump the throttle,with the engine not running
maybe check it with a vac gauge on the vac nipple on the carb with it running,
check you timming with a light or pull your #1 plug,up on top dead center,look to see if timming marks line up on the t cover and see where your rotor is pointing to rule out it jumping time,it will run jumping one tooth but not very good,2 teeth and it wont run
look at your fuel filter also...
thats some ideas to start you checking maybe
good luck and post an update with it later
